Old 04-27-2007, 09:23 AM   #1
Default Can the lossi XXX4 handle powerful motors?
I was palnning on getting a lossi XXX-4
I wanted to put a serious motor in it. 10 turn would be the minimum
Can I put 8 turn motor in or will the gearbox die.
Can this truck handle serious motors?
george_georgoul is offline   Reply With Quote
Old 04-27-2007, 09:27 AM   #2
RaceAce701's Avatar
Trader Rating: 86 (99%+)
it shoud handle a 10t no problem
i ran that in mine it had a little belt skip coming out of the tight 180 high traction corners
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 04-27-2007, 10:08 AM   #3
Alltapdout's Avatar
I've seen Novak GTB 3.5's run with not a single issue.. Except there hard to keep on the ground. I think it was tring to fly. . My LHS dealer goes to the extreme with everything.
Alltapdout is offline   Reply With Quote
Old 04-27-2007, 10:42 AM   #4
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Why? Most tracks you cant even put that power down, and its not a truck.
Too many people just want to go get the fastest, then wonder why they cant control it.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 04-27-2007, 01:04 PM   #5
NJA82's Avatar
Trader Rating: 33 (100%+)
Send a message via MSN to NJA82
I spose a good thing about todays current batteries and brushless motors allow you to basically run a 40,000 rpm motor or around that size and simply limit the throttleon the transmitter much like a carb restrictor in a nitro engine, this allows you to have the biggest if need be and also something smaller if you choose to go smaller, todays ESC`s have no worries having limited throttle and would behave much like a smaller wound motor having the throttle limited. I have a GTB 6.5 in my XXX4 G+ but if the track wont allow that kind of power and speed i can simply limit the throttle on the transmitter. Then i have a 7.5 or 8.5 etc.
NJA82 is offline   Reply With Quote
Old 04-27-2007, 03:50 PM   #6
I run a 9x2 in mine, no issues
gatermaxx is offline   Reply With Quote
Old 04-29-2007, 10:13 PM   #7
MadRacer's Avatar
myn was bullet proof..
Boondal vintage Tamiya's
https://www.youtube.com/watch?v=vtmCddStNyM
QLD State Titles winner in 6S EB CAT
MadRacer is offline   Reply With Quote
Old 04-30-2007, 05:11 AM   #8
Trader Rating: 44 (100%+)
people run bl motors on lipo's which are much more than any brushed motor that is 9 or above turns lol...a 3s +5700 would be insane...and the buggy can take it...as long as you keep everything in check
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 07-10-2008, 05:14 PM   #9
Shane_S's Avatar
Trader Rating: 22 (100%+)
Send a message via ICQ to Shane_S Send a message via AIM to Shane_S Send a message via MSN to Shane_S Send a message via Yahoo to Shane_S
from what ive seen i think it will. Just keep an extra belt or 2 on hand just in case. You may want to upgrade the diff cups also.
Shane
Shane_S is offline   Reply With Quote
Old 07-10-2008, 05:51 PM   #10
badassrevo's Avatar
Thumbs up
Exactly what he said!! Mamba Max 5700 3s INSANE
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 07-10-2008, 06:36 PM   #11
scott54's Avatar
There's something about seeing a XXX4 with a 4.5 being held wide open! I don't know if it's the whining of the belt or what.. The car may not handle the best but that belt sound was cool.
**** I've seen guys who just want the INSANE speed so they buy the mamba 7700 or the Novak 3.5.... and pair it with a cheap battery pack with cuts that speed in HALF! If you're shooting for salt-flat speed runs... get a good pack too! And tell us how it went!
TLR Racing - ARCS Speedway - B-Fast Racing - Dialed RC - G-Force
scott54 is offline   Reply With Quote
Old 07-13-2008, 12:07 AM   #12
Motoman's Avatar
I was wondering the same thing. So in general, it will handle a powerful brushless setup like the mamba 5700 on 2-3cell lipo? What size lipo can I fit in it? Has anyone tried to fit a 2s2p 8000mah lipo? Does it really handle a lot better than say a 2wd stadium truck? I'm thinking yes, but I've never even seen one at our track and much less driven one.
BL Revo
BL X-1 CR
BL XXX-T MF2
Motoman is offline   Reply With Quote
Old 07-13-2008, 12:25 AM   #13
NOTFASTENOUGH's Avatar
Trader Rating: 24 (100%+)
My brother runs a 4.5R and a 4800 lipo in his XXX-4. with no problems.
And I run a 5.5R and lipo in my XXX-4 also no problems.
NOTFASTENOUGH is offline   Reply With Quote
Old 07-13-2008, 02:54 AM   #14
I've fit a Maxamps 2s2p 6000 mah, but not before I filed the little "cell nub" completely off the battery holder; the pack is right at the the height limit. Given the dimensions listed for the 8000 mah and the tight fit of the 6000, I'd wager that the 8000 would not fit unless you elected to use strapping tape instead of the battery bar.
3s in any 1/10 scale is just overkill, in my opinion. My 2s2p with a Novak 5.5 has way too much power, even for just street bashing, and that's using the Novak gearing recommendation (3 pinion teeth down from standard).
r00t61 is offline   Reply With Quote
Old 07-13-2008, 06:41 AM   #15
Alltapdout's Avatar
I'd had a maxamps 8000 in mine, I just had to make my own battery strap to hold it in. However, unfortunitly mine didn't last too long... The softback was damaged from the chassis.
hopped up xxx4 G+ with 2 19T motors jsmax R/C Items: For Sale/Trade 3 12-07-2006 07:50 PM
lossi-ofna mart1968 R/C Items: Wanted to Buy 0 03-16-2006 06:43 PM
Francis & Kinwald(lots of Trinity Blue) XXX4, TC3, Motors, Batts, etc. teamlosi27 R/C Items: For Sale/Trade 5 10-17-2004 12:46 PM
FS/FT brushless, xxx4, twinforce, losi stuff evx motors pcnutz R/C Items: For Sale/Trade 24 10-14-2004 11:27 PM
Lossi xxx-nt F/S Caesarsalad R/C Items: For Sale/Trade 4 12-07-2002 12:14 PM
