Old 04-26-2007, 02:41 AM   #1
wothrottle's Avatar
Default engine eats plugs, on an on
my os vz-b (non turbo) eats plugs after 1 tank almost every plug tested died.
Im running this in a xb8, using graupner 25% and orcan 25%fuel,whereas the graupner fuel is specially designed for os engines, orcan was only tested.
plugs were os 8,a3,a5 some other brands and heat ranges. all died quickly.
there is no visible damage to the coil, not even an anormal colouration.
the connecting rod bushing seems fine, no feelable play so far.
please help me, I dont know what to do anymore.
wothrottle is offline   Reply With Quote
Old 04-26-2007, 05:26 AM   #2
i dont know much but all i got to say is stop spending your freakin money on glow plugs there pretty expensive if you ask me.
super jato dude is offline   Reply With Quote
Old 04-26-2007, 05:52 AM   #3
Is the button pitted? How about the top of the piston? How long have you been running the engine?
Fear_of_Midgets is offline   Reply With Quote
Old 04-26-2007, 07:40 AM   #4
Either too lean or too rich.
AreCee is offline   Reply With Quote
Old 04-26-2007, 08:42 AM   #5
Trader Rating: 96 (100%+)
Lean.
Are you running the tank dry every time? If so, when it gets low on fuel it'll start to lean out right on the last few drops of fuel.
Are there shims under the head button? Checking your temps with a temp gun?
You should see a stream of smoke coming the from exhaust at all times.
K.Copeland is offline   Reply With Quote
Old 04-26-2007, 02:16 PM   #6
Merciless's Avatar
Send a message via ICQ to Merciless
bottom end lean i'd guess. It probably isn't even running hot. But if the bottoms over lean you'll do plugs every run... I know .. I've done it
Merciless is offline   Reply With Quote
Old 04-26-2007, 03:42 PM   #7
sport10's Avatar
Originally Posted by xrayeddy
Lean.
The engines do not run lean long enough at the end of the tank to cause this to happen. It is something else like not having enough shims for the amount of nitro or tuning the motor too lean.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 04-26-2007, 03:57 PM   #8
Francis M.'s Avatar
open the motor and make sure to clean it out. Also check your rear bearing.
Francis M. is offline   Reply With Quote
Old 04-26-2007, 04:06 PM   #9
racer34v's Avatar
Trader Rating: 126 (100%+)
Send a message via Yahoo to racer34v
what kind of glow charger are you using? If you use the power panel kind make sure its pluigged into the yellow terminal side not the red and black terminal side or youll be sending 12v though that 1.5 volt plug...!!!
racer34v is offline   Reply With Quote
Old 04-27-2007, 01:56 AM   #10
wothrottle's Avatar
im using a 1,2 v sub-c batterie for the glow charger.
the connecting rod bearing seems fine, how to check the rear bearings?
thanks
Old 04-27-2007, 10:49 AM   #11
nitroveins's Avatar
thanks
sounds like your rod has slop in it. i had a picco xp that shot glow plugs for a whole weekend and come to find out the rod was stretched.
nitroveins is offline   Reply With Quote
Old 04-27-2007, 11:08 AM   #12
wothrottle's Avatar
hi
is such a rod slop feelable? mine seems good, but since Im a nitro rookie maybe I overlooked something.
do you have a link for a how-to on nitro motor rebuild?
Old 04-27-2007, 11:46 AM   #13
Revoguy's Avatar
Default um
try putting a extra washer on the glow plug
almost time for off season so items i have for sale
1.traxxas revo on ebay
2.traxxas 3.3 engine on ebay
3. roto start system on ebay
Revoguy is offline   Reply With Quote
Old 04-27-2007, 11:47 PM   #14
nitroveins's Avatar
hi
take the backplate off then work the piston up and down you will notice play the closer it gets to TDC (Top Dead Center). how much fuel have you run thru you engine?
Old 04-28-2007, 01:37 AM   #15
wothrottle's Avatar
did that already ,changed nothing..
New Novarossi .21 Engine Parts & Plugs F/S Nitro-mech R/C Items: For Sale/Trade 17 08-23-2008 08:39 AM
McCoy Plugs in an OS Engine crazy4wdracer Nitro Off-Road 3 07-07-2008 07:08 AM
F/S: O.s. .12 engine, glo plugs, glo ignitor KorruptedKarbon R/C Items: For Sale/Trade 4 01-03-2008 10:32 AM
Plugs for OS Vspec buggy engine straightaway Nitro Off-Road 12 11-14-2007 10:03 PM
Plugs and my engine RC Paperboy Onroad Nitro Engine Zone 4 06-28-2005 06:29 PM
