Old 04-26-2007, 03:54 PM   #16
Vato Loco's Avatar
Originally Posted by streetracer745
how much wider are they anyways? and why couldnt you use the turbo system with BL? it would still be 8.4V like the limits of most BL systems.
ill admit that your rusty is a rocket. ive said that before. but would the turbo system really make it so you cant use BL?
I was told the Turbo can't take how fast the power get sucked through it! I fried one already. on my sons rig with a brushed motor the other one held up fine.....Neat toy. it boost your power but kills the run time!
Size: 1 1/16" x 2 1/8" x 5 3/8"
Vato Loco is offline   Reply With Quote
Old 04-26-2007, 03:59 PM   #17
streetracer745's Avatar
Send a message via AIM to streetracer745
yeah. well ill run 6.6V and if i want mroe ill get a turbo and see hwo it does
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 04-26-2007, 04:02 PM   #18
Vato Loco's Avatar
I want to get a diffrent motor to handle both packs! damn thing will be giong warp drive!LOL's
Old 04-26-2007, 05:08 PM   #19
hmm. seeing what your rusty does with a 5700 in it. i wonder how my DI will do with that battery and a 7700 in it!
Old 04-27-2007, 01:58 AM   #20
Trader Rating: 96 (100%+)
The batteries are light and charge time is 1/3 of nimh packs. If anyones interested I've got 2 3s1p packs for sale, they'll fit in a truck easily, and if your running a Mamba, you dont have to worry about too much voltage.
K.Copeland is offline   Reply With Quote
Old 04-27-2007, 03:34 AM   #21
v1r killer's Avatar
just wondering what the differece in charges are. can i charge mimh with a lead acid charger and why?
v1r killer is offline   Reply With Quote
Old 04-27-2007, 08:02 AM   #22
Trader Rating: 26 (96%+)
You need a nimh charger for nimh cells because the nimh cells will be ruined if you over charge them. The chargers are designed to detect when the nimh cells are charged. You can find chargers that will charge a nimh pack for around $50. However, they can go all the way up to $400+ for a high quality one. These a123 cells like we are talking about require a differant charger too.
party_wagon is offline   Reply With Quote
Old 04-29-2007, 06:25 PM   #23
Default A123 cells
How long does your rusty/pede run? Have you raced it? Don
DLS II is offline   Reply With Quote
Old 04-29-2007, 06:38 PM   #24
With an MF2, 19t motor, 2s1p pack on a medium sized track, I had no problems with 6 minute mains
Old 04-29-2007, 07:55 PM   #25
what is the maximum run time with the 2s1p 2300 you have? will it last 15 minutes? and wouldnt a brushless give you a little more run time? because i know my reedy gives me a few minutes extra in my tc than a regular motor does
Old 04-29-2007, 09:07 PM   #26
2s1p with a low kv brushless, and not driving it like you stole it might give 15 mins run time. I know with 19t motor I could run for at least 7 mins. I also used 2s saddle packs in my XX4 and made 6 min mains with no problem, and the xx4 probably has the least effecient drivetrain out of any 4wd.
Old 04-29-2007, 09:28 PM   #27
well i drive like i stole all my cars. and im going to be using a high kv. and i also just realized that the 2s2p wont fit in my buggy!its like 2mm to wide!
Old 04-29-2007, 09:31 PM   #28
They are a little tricky to fit in cars but having charge times cut in half and no worries about it going up in flames like some lipo powered cars I've seen, is well worth the time it takes to make a new battery strap.
Old 04-29-2007, 09:39 PM   #29
dark impacts mount in the center and are surrounded by plastic. the only way to fit it is to sand out each side a little bit.
Old 04-30-2007, 07:36 AM   #30
Where is the cheapest place you guys have found to purchase these packs and how much current does the charger require from a power suply?
A123 batteries jopor Electric On-Road 19 10-23-2008 01:34 PM
a123 Batteries in RC18? haulin79 Radio and Electronics 1 07-06-2008 11:26 PM
FS/FT a123 batteries and charger pilsner6981 R/C Items: For Sale/Trade 7 05-15-2008 11:47 PM
Hypersonic Turbo for A123 batteries James35 Radio and Electronics 0 10-30-2007 10:57 AM
A123 batteries for European people rcmelted Electric On-Road 2 05-06-2007 05:07 AM
