Old 04-23-2007, 11:04 AM   #1
Default Breaking in motor
i just got a new novak brushless 6.5 motor. i was wondering if there is a proper way to break in a brushless motor. or any ways i can make this motor last.
any ideas would be greatly appreciated
DR1919 is offline   Reply With Quote
Old 04-23-2007, 01:00 PM   #2
Rysuleod's Avatar
You don't break in brushless motors. 'Breaking in' refers to making the brushes wear down until they are fully seated on the commutator on a brushed motor. Brushless has no brushes so no break in!
If your goal is to make it last a long time then minimize heat buildup. Avoid running it for excessive amounts of time, and gear appropriately so you don't ever go into thermal protection mode (aka shut down). Ensure you have proper ventilation even if that means putting a stupid breakable fan on top of it.
Rysuleod is offline   Reply With Quote
Old 04-23-2007, 03:04 PM   #3
swopemike's Avatar
Follow the instruction booklet. Occasionally open up the endbell (3 screws x 2.0 mm) and blow out with clean compressed air. You can use motor spray on removed components, but they don't recommend using motor spray inside the motor (I asked tech support why - they said you don't want to drive dirt down inside the electronic guts). Use a small drop of light bearing oil from time to time (once per race day) on the exposed bearing. I also put a small drop of oil on the end of the rotor where it goes down into the can, since I can't lube it from the outside. I probably opened mine up once every 2-6 race weekends.
Using a heat sink might help with heat. But the 6.5 should last you a long time in general if you do basic common sense stuff you already know (like don't run it underwater, that kind of thing).
swopemike is offline   Reply With Quote
Old 04-24-2007, 10:43 AM   #4
thanks ill look into doing that
Breaking In my Brushed Motor Chris__RC Electric Off-Road 13 07-02-2008 11:31 AM
Breaking in elec. motor CT9A Singapore R/C Racers 5 03-15-2007 09:19 PM
Help with cleaning/breaking in a motor D4nny06 Rookie Zone 3 02-20-2007 03:21 PM
Need help on breaking in a motor (CO27) falconcg Electric On-Road 1 11-30-2006 10:13 PM
Breaking-in Motor Secret_weapon Electric On-Road 2 09-12-2005 05:04 AM
