Oil weight comparison >
Old 04-19-2007, 05:38 PM
DiscoDan's Avatar
Default Oil weight comparison
I personally need the info right now, but I thought it might be good to have a thread like this for shock and/or diff oil comparisons between brands.
What weight of X brand crosses over to XX brand... etc.
My question is how does Losi shock oil compare to AE shock oil?
thicker? thinner? similar?
I'm trying to follow a setup sheet but Losi oil is not carried by my LHS
Opinions...
DiscoDan is offline
Old 04-19-2007, 05:42 PM
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Losi oils are thinner than AE's. I use Losi shock oils and AE Diff lube.
BuggyKing is offline
Old 04-19-2007, 05:44 PM
try this.....http://www.twf8.ws/php/tip/shock.html it should work now...
xrayracer33 is offline
DiscoDan's Avatar
Thats what I was afraid of.
The setup sheet I am following calls for 55w losi front... 45w losi rear
Any thoughts on how that translates into AE oil?
DiscoDan is offline
Old 04-19-2007, 05:45 PM
DiscoDan's Avatar
Originally Posted by xrayracer33
try this..
bad link
DiscoDan is offline
Old 04-19-2007, 05:48 PM
BuggyKing's Avatar
That as Losi weight is too high. That is like for the European tracks. I usually run 25 weight up front and 20 weigh in rear with Green springs front, Pink springs rear. Also 57 black pistons with 30 thousandths limiting front and 60 thousandths in rear.
Old 04-19-2007, 05:49 PM
DiscoDan's Avatar
I'm setting up a Jammin CRT... for some reason the driver uses Losi oil...
DiscoDan is offline
Old 04-19-2007, 06:03 PM
link fixed now.....here it is again http://www.twf8.ws/php/tip/shock.html
Old 04-19-2007, 06:35 PM
DiscoDan's Avatar
Thank you... explains everything I needed to know... and now it's here for all.
DiscoDan is offline
Old 04-19-2007, 07:28 PM
tmail55's Avatar
Trader Rating: 61 (100%+)
That's the site I've used for about six months!
Stock AE AND now Losi shock oils to tune per track!!!
tmail55 is offline
Old 04-19-2007, 07:31 PM
BuggyKing's Avatar
tmail55,
Thats an interesting site. I will look into it more.
