Carb Help
Carb Help
does any one know how to tune a carb, I know there are three screws but I dont know what two of them do, I know one sets your slide stop and the rest I am lost.
Frizman
Frizman
I bought it from a friend and he trew out the instructions like a retard, I bought it with a blow connecting rod and since I am a machienest I cnc out a new one now I got it runnig but it runs at about 250 f at half way threw a tank. I was told it should runn about 200 F and dont know how to tune it
Frizman
Frizman
250 really isn't bad. As long as it's under 260ish, you should be fine. The largest and most prominant adjuster(should be sticking up and an angle from the carb) is the Primary Mixture setting. There should be a small one on the throttle side, that's the Bottom End, or Idle Adjustment. Clockwise is richer, counter is leaner. Richer is cooler and slower, leaner is faster and hotter.
Sorry about the instructions comment, we have a TON of kids come on here, and ask for directions that came in their box...
it is a thunder tiger pro.21R motor for the thunder tiger mirage. it is about 50 F outside here right now and that is were I have it running is out side. I have turned the screws slightly were the fuel tube goes in and the big one on the carb, I have not turned the one that ajusts the idle speed. the car is pushing out blue smoke upon start up and turns to white after the engine has been idleing through 1/4 tank after that the temp starts climbing. I dont know if maybe it is the cold weather being at 50 F that is making it run hotter or not.
the engine has had 4 tanks threw it on idle so it should be broke in
Help!
Any ideas on this?
I was removing my carb and broke the back side of the lip or the flange near the bottom. The lip is just below the first oring. Anywho I have a Race Saturday and I'm wondering if cilicone will seal it ok until I can buy a new carb. Will it effect anything if I can get a good seal?
I would think the silicone will work but I would use high temp other wise you might end up melting the silicone and letting it get into the engine.
I will try the truning the screws one hr.
Cool!
Cool!
Thanks!
Thanks!
