Carb Help
Old 04-18-2007, 11:25 AM
Default Carb Help
does any one know how to tune a carb, I know there are three screws but I dont know what two of them do, I know one sets your slide stop and the rest I am lost.
Frizman
frizman is offline
Old 04-18-2007, 11:32 AM
R40Victim's Avatar
Did you get it used, or is it in an RTR? You should have recieved an Instruction Booklet with your purchase...
R40Victim is offline
Old 04-18-2007, 12:10 PM
I bought it from a friend and he trew out the instructions like a retard, I bought it with a blow connecting rod and since I am a machienest I cnc out a new one now I got it runnig but it runs at about 250 f at half way threw a tank. I was told it should runn about 200 F and dont know how to tune it
Frizman
frizman is offline
Old 04-18-2007, 12:30 PM
R40Victim's Avatar
250 really isn't bad. As long as it's under 260ish, you should be fine. The largest and most prominant adjuster(should be sticking up and an angle from the carb) is the Primary Mixture setting. There should be a small one on the throttle side, that's the Bottom End, or Idle Adjustment. Clockwise is richer, counter is leaner. Richer is cooler and slower, leaner is faster and hotter.
Sorry about the instructions comment, we have a TON of kids come on here, and ask for directions that came in their box...
Old 04-18-2007, 12:36 PM
MADMAN23's Avatar
Trader Rating: 27 (97%+)
i run my nitro's 220 ... what motor is it.. then we all can help you.. 250 at half a tank still left in it is to lean...
MADMAN23 is offline
Old 04-18-2007, 12:38 PM
MADMAN23's Avatar
dose it have blue smoke coming out of it?
MADMAN23 is offline
Old 04-18-2007, 02:15 PM
it is a thunder tiger pro.21R motor for the thunder tiger mirage. it is about 50 F outside here right now and that is were I have it running is out side. I have turned the screws slightly were the fuel tube goes in and the big one on the carb, I have not turned the one that ajusts the idle speed. the car is pushing out blue smoke upon start up and turns to white after the engine has been idleing through 1/4 tank after that the temp starts climbing. I dont know if maybe it is the cold weather being at 50 F that is making it run hotter or not.
frizman is offline
Old 04-18-2007, 02:58 PM
Tech Legend
Cain's Avatar
Trader Rating: 259 (100%+)
give thunder tiger an email and call and see if you can get a manual. I think they also sell the engine or something similar at A-main hobbies.
Cain is offline
Old 04-18-2007, 04:16 PM
MADMAN23's Avatar
ok here what i would do srcew the hsn all the way in ...then srcew it out 3-1/2 to 4 turn's .. is the motor broken in.. how many tank's has it had....
MADMAN23 is offline
Old 04-19-2007, 10:19 AM
the engine has had 4 tanks threw it on idle so it should be broke in
frizman is offline
Old 04-19-2007, 10:24 AM
lean the bottom end 1hr (the one on the carb body)
richin the top end 1 hr ( where the fuel line plugs in)
and go from there and see what your temp is and let me/us know
Robert.Hull is offline
Old 04-19-2007, 11:14 AM
Dirt McGirt's Avatar
Default Help!
Any ideas on this?
I was removing my carb and broke the back side of the lip or the flange near the bottom. The lip is just below the first oring. Anywho I have a Race Saturday and I'm wondering if cilicone will seal it ok until I can buy a new carb. Will it effect anything if I can get a good seal?
Dirt McGirt is offline
Old 04-19-2007, 11:21 AM
I would think the silicone will work but I would use high temp other wise you might end up melting the silicone and letting it get into the engine.
I will try the truning the screws one hr.
frizman is offline
Old 04-19-2007, 11:40 AM
Default Cool!
Cool!
Thanks!
