My 4 wheel drive .21 Savage only powers 2 front wheels >
Old 04-18-2007, 09:48 AM
Syz
Angry My 4 wheel drive .21 Savage only powers 2 front wheels
hi all
as you can see im new to the forum. I own a .21 savage. I recently pulled it out of storage and decided to start riding it again.
I have a small (i hope) problem with it.
It is a 4 wheel drive but it only powers the 2 front wheels. When I pick it up and and give it some gas the back wheels do not turn at all. I took a look underneath while it was running and the drive shaft (dogbone) which powers the back wheels is not turning at all.
What could I start looking at? Any help is appreciated.
Syz is offline
Old 04-18-2007, 10:20 AM
SIRMAXXALOT's Avatar
Sounds like the tranny went? Never had a Savage bhut that is the only logical place it could be---or if it has a set screw for the dogbone to tighten to the output shaft on the tranny I would start there.
SIRMAXXALOT is offline
Old 04-18-2007, 10:29 AM
macnkitty2002's Avatar
yes, i would go over each and every screw on the drivetrain first and make sure everything is cinched down tight. then i would take a look at the diffs, even though they are most likely not the problem. then take off the tranny and tear it apart.
macnkitty2002 is offline
Old 04-18-2007, 12:18 PM
amain's Avatar
if the drive shaft is not turning its obvisouly the center diff/tranny.
amain is offline
Old 04-18-2007, 12:41 PM
MADMAN23's Avatar
Trader Rating: 27 (97%+)
sound's liken the output shaft is loose.. i had that happen with my savage and LST before...
MADMAN23 is offline
Old 04-20-2007, 09:26 AM
Syz
thats what it was,
should have checked my screws before i posted dumb questions
Syz is offline
