kyosho ZX5 chassis broken at front battery post >
Old 04-16-2007, 11:08 PM
Trader Rating: 52 (98%+)
Default kyosho ZX5 chassis broken at front battery post
I drove my new kyosho zx5 for one battery pack and the chassis chunked off at the front battery post. Is this common?
I drove very easy and the track is very soft. I am a decent driver. I go to the track 1-2 times a week for the past 4 years. I am usually in the b main if I race.
One guy at the track drove one pack and his broke too. The other guy drove 3 laps and his front shock tower broke.
I am very disappointed at this car. I have several kyosho gas 1/8 buggies and they are great but this ZX5 is not good. Maybe Kyosho should stick w/ gas buggies and get out of electric offroad.
straightaway is offline
Old 04-16-2007, 11:40 PM
TheTurtleMan's Avatar
Trader Rating: 31 (100%+)
Knock on wood, my car has been great. I think I broke one front shock tower the whole time I owned it.
I love this car.
TheTurtleMan is offline
Old 04-16-2007, 11:58 PM
GymBeam's Avatar
go on the kyosho thread. there is a post on this "problem"
they upgraded the chassis. you prob got the old chassis. the new chassis got a "+" shaped mould on the battery post.
i did break my old style chassis. my fault. bad crash. but i fixed it easy. just glue it back on and run a 3mm washer under the chassis and a button head screw.
i ran like this for over 10 races meets now and its all good.
i also got a new chassis now, but have never used it because the fix i did is holding up well.
zx-5 is very strong car. as strong as anything out there, and much better than losi, with a few hopups like aluminium tower holder and front lower alum brace.
the only thing that is "weak" is the front shock tower. however the good thing is that when it breaks, it doesnt break off completely and therefore you will be able to finish the heat with it.
and no offence, but you can't drive an electric car like a 1/8th. they just cant be bashed like a 1/8th. teaches you to be more carefull.
i heard this one guy say he broke hing pins, arms etc. i told him thats strange i never broken arms or pins before. then i saw him drive and i then knew why....
GymBeam is offline
Old 04-17-2007, 06:34 AM
foolio's Avatar
I had the exact same thing happen as GymBeam and I did the washer/glue fix. Now I have a brand new chassis in my pit box that I have yet to use. I bet I have raced 100 packs and had some serious wrecks without the "fix" failing.
foolio is offline
Old 04-17-2007, 10:21 AM
I have several 1/10 electric buggies, so my driving should not be an issue.
Since I have to get a new chassis eventually, has anyone tried the conversion: KM Concept conversion
http://www.speedtechrc.com/store/ebp...id=482&id=6029
Old 04-17-2007, 10:38 AM
I just talked to Kyosho USA, they don't have a revised chassis. Can someone post a pic of the reinforeced chassis? Thanks.
Old 04-17-2007, 11:27 AM
foolio's Avatar
There is no question that they did release a revised chassis. Whoever you talked was apparently not informed. Here is a link from amainhobbies website that clearly shows the new cross bracing:
Revised Chassis Pic
foolio is offline
Old 04-17-2007, 12:58 PM
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I broke mine in the first few packs...nothing dramatic, just flipped it off a roller deal and the battery was hanging out. I just poked a hole next to the original location and used a button head to hold the post. It never broke and I ran it for months after than until I finally replaced the chassis.
Turbo Joe is offline
Old 04-17-2007, 02:40 PM
Revised Chassis Pic
I just place an $100 order from A main (free shipping ).
Thanks for all your help. I am going to try the 3mm washer + button head method. Until it breaks, I will have a new chassis coming. $26 for a chassis is not bad, it is actually cheaper than the suggested retail in Japanese $.
Old 04-17-2007, 05:22 PM
foolio's Avatar
If it's not too late, you might request that they make sure and send you the updated chassis. They might have some of the old ones in stock still. That's what I did and they emailed me back saying they made sure I had the right one...
foolio is offline
Old 04-17-2007, 06:04 PM
Team ComeBack's Avatar
Did it break landing coming off a jump? That seems like a weird place for it to break...
Team ComeBack is offline
Old 04-17-2007, 08:23 PM
i see some zx5 going around they look real strong
POOKGAI66 is offline
Old 04-19-2007, 10:25 PM
no, what I heard was that if the space foam were not used, battery will ram hard toward the post when landing to hard. This will reduce it from happening.
However someone said even if the foam is used, it will still break if land too hard. That is why they updated chassis.
Old 04-21-2007, 02:52 PM
I see.... maybe I should get a new chassis....
Old 04-22-2007, 01:31 AM
WheelNut's Avatar
I have the old chassis and I put a bunch of epoxy around the front battery post to help strengthen it. Once our track gets up and running here soon I'll see how it holds up.
WheelNut is offline
