Old 04-15-2007, 08:01 PM   #1
Trader Rating: 18 (100%+)
Default Off-road buggy question
I just started off-road 1/8 buggy <was running all on-road> and I have a question on springs, and oil.
I have a Mugen MBX5 and when I jump the buggy over a triple, the nose of the buggy dips way down. Almost to where when I throttle up it will not raise the front back up enough to land correctly.
Do I need to change front/rear springs, and oil?
I have 40 wt/ in the front, and 35 wt/ in the rear with gray springs in front, and white in the rear.
appreciate the help
brc358 is offline   Reply With Quote
Old 04-15-2007, 08:45 PM   #2
schmelme's Avatar
when you say dips way down. Do you mean in the air, landing or on the face of the jump?
schmelme is offline   Reply With Quote
Old 04-15-2007, 08:49 PM   #3
Default Off road buggy
Sorry bout that,
After I take the jump, the front of the buggy will nose down while it is in the air.
I throttle it up, but the nose is so far down, the throttle will not raise the front of the buggy
Old 04-15-2007, 08:50 PM   #4
pirate60's Avatar
Trader Rating: 15 (100%+)
Could be a rear ride height issue. If the rear of the car is bottoming out on the face of the jump then it will 'kick' the rear of the car up like you describe. Raise the ride height a little and see how that goes.
pirate60 is offline   Reply With Quote
Old 04-15-2007, 08:51 PM   #5
Nitroaddicts's Avatar
well, it can be 2 things..
1) Stiffen up the front.
2) The rear is bottoming out on the jump and throwing the rear up and nose down. In this case stiffen the rear.
www.NITROADDICTS.com
Get Free T-Shirts with Nitro Points!
Need Track TShirts?
http://www.facebook.com/AmericanGFX
Nitroaddicts is offline   Reply With Quote
Old 04-15-2007, 09:36 PM   #6
Default Off -road buggy
Thanks for the tips.
I will try these out and see how it does.
thanks again
Old 04-18-2007, 03:06 AM   #7
I had that problem once and found out my front wheel bearings were wasted. Once I let off the throttle, the bad bearings would slow the drive shafts down as if I was applying my brakes. It kinda had the effect of using drag brakes. I changed the wheel bearings, and the problem was solved. (Just something else you can check if it's not your ride height).
8ightScale/CJP is offline   Reply With Quote
Old 04-18-2007, 05:10 AM   #8
Make sure you have no brake drag or any drag in the drive line first off. Sounds like the rear of your chassis could be slapping the ground as you take off. Try gray springs all around with Mugen 400wt 5mm spacer front (CV's slightly above level) and Mugen 350wt 8mm spacer back (CV's level). If you wanna see the car really launch try the same spacers and oils with the blue springs. Hope this helps.
Fear_of_Midgets is offline   Reply With Quote
HPC Monthly Off-Road Race (1:8 Buggy, Truggy & EP Buggy) - September HPC II Malaysian R/C Racers 120 09-19-2006 12:57 PM
New to On-Road (tc4 question) CellBoy77 Electric On-Road 4 10-12-2005 02:32 PM
Electric on road or off road car or buggy racer965 R/C Items: Wanted to Buy 4 04-15-2005 10:55 AM
I have a nub off-road question =MisFitz= NuKe Electric Off-Road 8 07-08-2004 09:54 PM
Question on gearing options - On road vs Off road Ducati-Rider Nitro On-Road 1 05-04-2004 01:54 PM
