Old 04-14-2007, 09:47 PM   #1
Default Kyosho ST-R wheel extenders
how much steering should i gain by adding the 12mm extenders?
xrayracer33 is offline   Reply With Quote
Old 04-14-2007, 10:14 PM   #2
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
I didnt really gain much steering but i gained alot of stability.
infanterene is offline   Reply With Quote
Old 04-15-2007, 08:23 AM   #3
i am having trouble with it pushing on turn in under power..can't really carry any speed into it...my diffs are 7k front, 30k center, 3k rear. i am currently running a high bite blue groove indoor track. i have the khz knuckles if that makes a difference..i was going to bump UP the front diff to 10k (i've heard it's better that way) but i thought that would make it push more....
Old 04-15-2007, 09:44 AM   #4
pumpkinfish's Avatar
When I first built mine with the 7k front I hated it. It pushed like a champ. I am now running the following and it is so easy to drive:
(12mm wheel hex extender set)
Front:
- 700w Kyosho oil
- 1.4 pistons
- White springs (stock)
- Outside hole on shock tower
- Second hole from outside on suspension arm
- 20 deg caster blocks
- 2* toe out
- -1 to -2 degree camber
- 18,000 front diff oil (mixed)
- arms level
- middle hole on caster block
- A suspension holder/A bushings
- Low Block/L bushings
- front hole on ackerman
- sway bar stock/balls out
- droop limited one turn
Center
- 50 tooth spur
- 13 tooth clutch bell
- aluminum shoe/1.0 springs
- 22,000 Center diff Oil (mixed)
Rear
- 700w Kyosho Oil
- 1.4 pistons
- Long White Buggy Spring
- Outside hole in tower
- Second to outside hole in suspension arm
- 2,000 diff oil
- 3 deg anti squat block
- 2.5 rear toe block
- hubs 2/3 forward
- camber link inside lower hole in tower/outside hole in hub
- lower hole in rear hub
- sway bar 3mm/balls out
- droop limited one turns
- arms level
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Old 04-15-2007, 10:30 AM   #5
so, you are running cody kings setup? does the higher front diff fluid make it push more? or does it like more like a front wheel drive action?i.e. pulling through corners?
Old 04-15-2007, 11:59 AM   #6
I pulls more. I had a ton of push and it made it fell a lot better. I have since added a BCE extended chassis and KMW Big Bore Shocks and the truck is dialed now!
Kyosho RT6
Old 04-15-2007, 12:31 PM   #7
those are my next two purchases...talked to pops at kmw and i am ordering those big bores soon...thanks for the info..
Old 04-15-2007, 12:44 PM   #8
Trader Rating: 15 (100%+)
Thicker oil up front will make the truck push more off power (into turn) but help it steer more on power (out of turn). I tried 30k in the center diff and didn't like it at all, the truck felt too locked up. I would definitely drop it to 20k or 22k like CK's setup says. Cody's setup is fantastic, I would give it a try.
The 18k and 22k oils are just a guess. What he does is fill the front almost all the way with 20k and then tops off with a little 10k, then does the same in the center using 20k and topping off with 30k.
I also highly recommend the 11mm hub extenders (#IFW327BL), they really help the truck feel more balanced.
Shocker is offline   Reply With Quote
Old 04-15-2007, 01:02 PM   #9
what would it do if i dropped the center to 15-20k? or do you guys have a link to a site that i can read more on this?
Old 04-15-2007, 03:02 PM   #10
Try this:
http://rc411.com/pages/howto.php?howto=24&page=1
Kyosho RT6
Old 04-15-2007, 04:05 PM   #11
i found that site after i posted the question....LOL...thanks for all the help...do you guys know of any steering mods to do to get more throw?
Old 04-15-2007, 04:56 PM   #12
The 11mm hub extenders will give you a little more steering throw. You won't need anymore than that.
Old 04-15-2007, 05:09 PM   #13
i have the khz 12mm that will be here wednesday. along with the khz chassis braces and knuckles already on it so it should be good to go. gonna put ck's setup on it now.thanks for the info....
Old 04-17-2007, 10:14 PM   #14
Run the king set up it rips. I run that setup except 20k/20k/2k, I didint want to mix.
Kyosho Wheel Wrench or other 17mm Cain R/C Items: Wanted to Buy 0 04-17-2007 01:54 PM
WTB kyosho 2.0 starter box wheel sracer R/C Items: Wanted to Buy 0 03-12-2007 01:28 PM
Vintage RARE Kyosho Progess 4WS (4 Wheel Wheel Steering) assoc_driver Australia For Sale/Trade 0 01-16-2006 08:34 AM
Kyosho inferno wing/wheel set NEW go1d1e R/C Items: For Sale/Trade 1 06-12-2005 04:18 PM
Kyosho 1/10th electric quad (4 wheel ATV) gearhead R/C Items: For Sale/Trade 0 03-06-2005 05:35 PM
