BK1
Old 04-12-2007, 05:17 PM
Exclamation BK1
Ok so i have a Rustler with a mamba 5700kv and took it to the indoor track. there were buggies and i just couldn't make the jumps like they did, so now i want a buggy! I found a nice deal on a BK1, but i hear that its hard to find parts for them? is this true?
Rustler_5700 is offline
Old 04-12-2007, 05:48 PM
xxx-ntad2 racer's Avatar
Trader Rating: 24 (100%+)
you can pick up a bk2 pretty cheap now a days too. i don't think it's hard to find parts...it is an older car tho...
xxx-ntad2 racer is offline
Old 04-12-2007, 06:20 PM
jelly's Avatar
the bk1 is similar to the xxx-cr so you can use the same parts as the new car.
jelly is offline
Old 04-12-2007, 07:56 PM
AzBobby's Avatar
the BK2 and the cr parts will work on the bk1.
AzBobby is offline
Old 04-12-2007, 09:07 PM
so the arms and everything is the same on htm? if so what is the difference?
the one im looking at is entirely graphite
Old 04-12-2007, 09:13 PM
D Hunt 3's Avatar
If you get a BK1 when you break front arms put the CR hubs and arms on and I would suggest the rear hubs and arms from the CR so you get the more hub options. Also the CR steering rack.
D Hunt 3 is offline
Old 04-12-2007, 09:22 PM
so how much am i looking at for what you said, in terms of cost?
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Parts are not hard to find for the BK1. They are very to the CR buggy.
BuggyKing is offline
Old 04-12-2007, 09:24 PM
very to??
Old 04-12-2007, 09:38 PM
Old 04-12-2007, 10:01 PM
RCGaryK's Avatar
here's what you can add to your BK1 to bring it to CR specs:
XXXCR FRONT SHOCK TOWER - LOSA1104
FRONT ARM, VLA, EA3: XXXCR - LOSA1112
XXXCR STEERING BELLCRANKS, RACK - LOSA1621
REAR SHOCK TOWER,EA3: XXXCR - LOSA2100
REAR HUBS, VLA: XXXCR - LOSA2129
REAR SUSPENSION ARMS, VLA,EA3:XXXCR - LOSA2132
Those are the main components. I would also consider swapping out the graphite chassis and front/rear suspension mounts with EA3 ones as well.
RCGaryK is offline
Old 04-12-2007, 10:19 PM
is EA3 lighter?
Old 04-13-2007, 07:47 AM
is EA3 lighter?
Old 04-13-2007, 10:32 AM
I run my BK1 alot and have no problem with getting parts.I have been using the EA3 front arms (seem to be cheeper than the graphite) with the VLA's front and rear.
I like my "old" buggy.
Jammin"145 is offline
Old 04-13-2007, 11:04 AM
K_King's Avatar
Trader Rating: 41 (100%+)
is EA3 lighter?
Maybe a little, but its also more brittle than the EA3. If you are going to swap out everything for EA3, just buy a new kit. Honestly the BK1 will be fine. It sounds as though you are new so all of the extra setup adjustments wont do you any good right now. You could always add them later as you get more experience.
K_King is offline
