Old 04-11-2007, 10:17 PM   #1
PoLsKiE's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to PoLsKiE
Default t4 gearing
im going to be running a 10 turn in my t4 its a checkpoint 10t double what kind of fdr should i be in....and also what type of fdr should i be in for a checkpoint 19t let me know guys
PoLsKiE is offline   Reply With Quote
Old 04-12-2007, 04:39 PM   #2
AzBobby's Avatar
i have the same motor in 19t and i use a 19 when its cool outside and a 18 when its hot. for the 10t probably looking at a 17 to 19 all of these are with stock spur gear.
GO TECH
AzBobby is offline   Reply With Quote
Old 04-12-2007, 05:14 PM   #3
PoLsKiE's Avatar
ya it says run a 18t pinion i ran a 19 to be safe and it runs good it just heats up my 3800's LIKE CRAZY but its HOT outside
Old 04-12-2007, 06:36 PM   #4
Hey guys, i got a t4 with a MM5700 on the way. I'll be running mostly 3800 and 4200 matched packs. What gearing do you guys run ? I have a 100' by 100' packed sand track. lots of high speed sections and techical in the middle. The sand is pretty compacted and wind blown so theres NOT alot of drag. Looking to stock up on a few spur gears and pinions. I run a revolution mod 14tx2 with 87 spur and pinions from 17 to 20. thanks. Dan.
danimal1965 is offline   Reply With Quote
Old 04-12-2007, 07:54 PM   #5
AzBobby's Avatar
you'll be good with what you got.
also polskie how was running a 19 the first time being safe? not sure i understand, if you gear to high you will heat up your motor also. as well as being to low geared will heat it up too. if you have a temp gun try to get between 130 and 150 max with your gearing after six minutes.
GO TECH
Old 04-12-2007, 08:34 PM   #6
Thanks AzBobby. Dan.
Old 04-12-2007, 09:56 PM   #7
PoLsKiE's Avatar
oops sorry that was a typo i put a 17 and it runs nice... yes i have a temp gun i just need to get it out
Old 04-14-2007, 02:17 PM   #8
AzBobby's Avatar
good glad it worked out for both of you. as for the temp gun i keep mine much closer to 130 but some do run a bit hotter that use this method. i like longevity so i run a bit cooler.
GO TECH
Old 04-14-2007, 06:10 PM   #9
Trader Rating: 23 (100%+)
Send a message via AIM to AxiomJacob
i ran a 18/87 with a 12x3 in my t4 and it wasnt to bad. I would go with a 17/87 with the 10 and a 19/87 with the 19t.
Jacob
Proline Racing
AxiomJacob is offline   Reply With Quote
Old 04-15-2007, 12:41 PM   #10
"If you gear to high you will heat up your motor also. as well as being to low geared will heat it up too."
Short gearing will also create heat? How does this work, usually I get undesired performance results, but room temp motors and room temp batts with the short gears.
dupsta is offline   Reply With Quote
Old 04-29-2007, 07:48 AM   #11
Hey ,I'm ordering a Novak 13.5 to run in stock class with my mamba esc. Probably get the non pro without the new rotor in it. Don't want toget kicked into 19t after one race. LOL What kind of gearing is a good starting point? The track is technical,only one straight,about 90' long,medium size,clay ,sand,dirt mix. Dusty when dry but usually watered down before most races. Running stock 87 spur too. Thanks. Dan.
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
