Electric 1/8th Scale conversion kits.
Random shot i took after racing 2 weeks ago.
I know you cant see much but w/e lol.
Nice thinking out of the box, but wont the motor mounted like that cause handeling issues?....Looks good though.
mechanical brakes and reverse...
Has anyone worked out how to have direct drive, mechanical brakes and reverse with the TeknoRC kit?
I managed to get it working but he ... it was an nightmare and dont know anymore what i have exacly done but i moved the reverse to the grip button on my 4PK and have brakes on the normal trigger. I beleive some mix channels with changed EPA's en then linked the button to that specific mix chan with an new EPA.
I did this truck for a customer. I am trying to get a used .5 now and will look at it again when I do.
I will sell this kit to anyone interested.
$75.00
Dan
These trays will hold ANY Lipo Saddle pack from MAX AMPS and any NIMH saddle pack configuration safely and secure.
Dan
Finishing up a MBX5T conversion. The balance came out pretty good with the 6S pack. Will finalize some wiring runs and get it finished soon. The original weight without tires and fuel was 3333 grams (full tank of fuel would be approx 168 more grams bringing the total to 3501). The weight after the electric conversion was 3436 grams without tires.
So you set the -ve exponential on the brakes to kick in at a point on the trigger after reverse would have normally kicked in. It's a balancing act. Too much reverse trigger and the brakes will kick in but a light push on the reverse trigger and it goes backward. You could go further and tune +ve exponential on channel 3 so reverse speed slams in with less trigger movement.
I eventually tuned it out completely cause I found practicing with no reverse made me a drive better lines and crash less.
hers some pics of my rcpd converted 2.0 cleaned up a bit, tekin 1550 motor on 5s pretty beastly motor on 5s, 4s on a small track isnt bad either! id like to see it on 6s!
Hey a buddy of mine has an old Ofna ravager and wants to electrify it. Is this possible? What would he use, and where would he get it?
