what the difference between esc braking and controller braking?
hey guys
one of the main aspects that im trying to achieve on my driving is how to brake coming into a corner wth an electric mf2 losi stock truck. What will help in the cars setup for braking? |
adding drag break using your esc....
Maybe you want to try a chassis adj'..Toe.
Rather than if you'r elect', mess with any fwd/rev throtle trim knob on you'r Transmiter?!? Toe......Frt out - Rr in, you can tune this kind of physical drag on anything with wheel's Excess adj will enhance that characteristic but sacrafice another. A little rear toe in gives all my stuff a drag/static brake at the sacrafice of top end speed. But Man will it Slow for control/turns,,,other adj. |
What is your truck doing coming into a corner? Is it pushing or plowing?
Drag brake is a real effective setup option for turning. Read your speed controls manual and try it out. I use between 20-30% drag brake. I have it high enough so I don't even have to press brake going around corners. Drag brake is just like an engine braking in a real car. |
thanks for your your help, yes my esc has a drag brake setting on it so ill try.
But if anyone nows whats the difference between using the braking setup on a hand controll to the esc? |
Are you pushing or plowing coming into turns?
well i think ithe back is pushing as it slides out
