Old 04-07-2007, 09:14 PM   #1
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Default Pro Line Edge Truck tire question
Ok whats the deal with these tires. I have them mounted unlike anyone else. Everyone has the directional ribs on the inside, but I have mine on the outside of the tire.
So my question is, what does running them in the different locations do?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 04-07-2007, 10:17 PM   #2
WheelNut's Avatar
Send a message via MSN to WheelNut
Depending on how you mount them it will change the steering characteristics. Moutning the directional ribs on the inside will put the "sharp" edge of that tread facing against the direction your turning so it will bite harder. Mounting the tire the other way will do the opposite and should smooth out steering response, wont catch as many edges (if your running on a broken dirt surface), and generally less front grip. If your on a high grip rough/broken track then the way you've mounted them will probably work pretty good.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 04-07-2007, 11:21 PM   #3
Do you have the letters inside? if so this is the less aggressive way to run the tire, as said by Wheelnut, in my experience, you really don't need to run them the other way, these are aggressive enough the way you have them. I have a set of edge with letters out, and the Losi equivalent the mounted the opposite way and prefer the losi, which i believe is the same way you have your edges mounted.
HTH
Rod
gatermaxx is offline   Reply With Quote
Old 04-08-2007, 12:23 AM   #4
K_King's Avatar
I have them reverse from this pic.
Old 04-08-2007, 12:46 AM   #5
WheelNut's Avatar
That is the less aggressive configuration you have them on.
•Brad Comis
Old 04-08-2007, 06:31 AM   #6
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Rod
The last pair I got had letters on both sides!!!!
Any way!!
I have a set mounted both ways, keep all your tuning options open!!
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 04-18-2007, 01:35 AM   #7
K_King's Avatar
I bought another pair and mounted like the pic, going to see how they do tomorrow hehe. Thanks guys!
1/8 Truck Tire Lot Pro-line/Panther LPR tomdav R/C Items: For Sale/Trade 4 10-28-2008 03:56 PM
NEW Pro Line LPR tire and wheel line is out KThatcher Nitro Off-Road 2 10-18-2007 05:56 PM
Foam tire edge clean-up tool rcfoolz R/C Items: For Sale/Trade 2 02-11-2004 09:52 AM
Foam tire edge sander Randy Caster R/C Items: Wanted to Buy 14 02-09-2004 09:37 AM
Pro-Line’s all-new Mugshot tire (UNRELEASED YET 1/8TH SCALE TIRE) bgolat R/C Items: For Sale/Trade 0 11-26-2002 12:30 AM
