Old 04-03-2007, 09:14 PM   #1
Trader Rating: 15 (100%+)
Default Engine tuning question - sputters at high RPM but plenty of smoke
Hi, I picked up a used 8ight for my first nitro car and I'm learning the tricks of tuning the engine. I'm getting some of them down - I know how to at least tune the low and idle enough to get it started and keep it running.
When I punch the throttle it'll fly on an open parking lot for 1-3 seconds but then it sputters and seems to idle despite my trigger being all the way down. Then it will come back to life for another second or two. 1 out of 4 times it'll stall out completely.
I was told that the stuttering is a symptom of being too lean and that I need to make the high needle richer. But I don't understand why I'd be seeing plenty of smoke if it's rich.
Arboleda is offline   Reply With Quote
Old 04-03-2007, 09:29 PM   #2
schmelme's Avatar
That sounds like a major lean bog to me. Back out the high needle a full turn and re-tune. DONT touch the mid range if it has one. What engine r u running?
schmelme is offline   Reply With Quote
Old 04-03-2007, 09:40 PM   #3
The engine is the 427 that comes with the RTR 8ight. You're advice is the same as what I've heard elsewhere as well. The only thing I'm confused about is that there's plenty of smoke - more smoke already than my brother's HPI Lightning RTR. You still think it's a lean bog?
Old 04-04-2007, 06:59 AM   #4
sport10's Avatar
The base settings for the 427 engine are:
High-Speed Needle- 2.5 turns out from bottom
Low-Speed Needle- 2.5 turns out from bottom
Reset the needles to this and see if your problem goes away. The high speed needle on this motor is touchy. It will go from too rich to too lean in a half a turn so make small adjustments.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 04-04-2007, 07:06 AM   #5
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Mhhh had same problem with my last STS .21 Team Engine ... and the problem was that i was using a too cold plug, try to go to a hotter one and retune the engine ... at least that resolved the problem for me ...
cya,
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-04-2007, 09:59 PM   #6
I returned my settings to factory and then got it all worked out. I'm almost fully tuned at this point. Thanks for the input.
Old 04-04-2007, 11:03 PM   #7
gubbs3's Avatar
It kind of seemed like you might have leaned the high end needle until you got good throttle response. Rule #1 is engine tuning is always tune the high end first. It controls the total flow of fuel to the engine and is the only needle affecting the mixture at more than 1/2 throttle. When you can open it up and get a nice crisp sing from the engine accompanied by a smoke trail then you can go ahead and tune the low end for throttle response.
gubbs3 is offline   Reply With Quote
Old 04-18-2007, 09:49 AM   #8
Richen the high end needle 1/2 - 1 turn. If it still does it, then start to lean it back out. You can still see exhaust fume from the pipe because it has some fuel to burn in the chamber, just not enough. My Dad found this out the hard way with his t-maxx and burned it up.
The Italion is offline   Reply With Quote
HIGH POWER ENGINE AND CENTER DIFF QUESTION !! dead1dave Nitro Off-Road 6 06-30-2008 07:31 AM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 07:04 PM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 03:01 AM
engine tuning question!!!! asd Nitro On-Road 2 06-14-2003 09:38 PM
Engine Tuning Question six60grizzly Electric Off-Road 1 03-07-2003 06:37 PM
