Old 03-30-2007, 05:46 PM   #1
Trader Rating: 19 (100%+)
Default Piston/Sleeve Question
How do you remove a piston/sleeve on an engine with a broken rod?
sjr456 is offline   Reply With Quote
Old 03-30-2007, 06:32 PM   #2
SKOT's Avatar
You have to take off the head and the backplate. Then push the piston and sleeve out through the top of the case. If it's a pull start engine you'll have to remove that before you can remove the backplate.
Here's a link to a good article with pictures.
http://www.nitromonkey.com/xoops/art...ticle.id+4.htm
SKOT is offline   Reply With Quote
Old 03-30-2007, 07:53 PM   #3
LOWGEARED's Avatar
Dont mean to interfere here but,,, why repost a thred that already exists!!!!!
My mach 15RE engine:
I took the head off to inspect it and the piston sleeve pulls out with no problems!!! Is this a sign of premature engine wear? It only has about 1 and a half gallons through it !!!!
How much resistance should there be when turning the flywheel all the way over at topp dead center?
Thats with everything back together and glow plug in as well.
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 03-30-2007, 08:45 PM   #4
LOWGEARED's Avatar
no bites yet?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-30-2007, 08:59 PM   #5
Thanks, but I can't use the ziptie method. Theres no way spin the flywheel and exert pressure on the piston due to the broken rod.
wtb: MT.12 Piston & Sleeve TC_Tuner R/C Items: Wanted to Buy 1 08-13-2005 06:11 AM
piston and sleeve question disaster999 Onroad Nitro Engine Zone 3 02-12-2005 11:29 PM
X12 Rody Sleeve/Piston friction question!? Frag Onroad Nitro Engine Zone 9 05-24-2004 02:58 PM
Piston/ Sleeve Pleskit Onroad Nitro Engine Zone 6 05-03-2004 11:57 AM
piston/sleeve nitromike Nitro On-Road 1 03-14-2004 11:02 PM
