Old 03-29-2007, 05:46 PM   #1
Default Marvel's Mystery Oil
How many use this for After Run Oil and/or Air Filter Oil? Mostly does anyone use it as Air Filter Oil?
Snipesr82 is offline   Reply With Quote
Old 03-29-2007, 08:27 PM   #2
d4man's Avatar
I've heard that marvel mystery oil is just like after run in oil.
I don't think you want to use MMO as an air filter oil. Its' too runny. You want something thick and gooey. I use some 2 stroke air filter oil bought from the local cycle shop.
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 03-29-2007, 09:16 PM   #3
D_Ames's Avatar
Send a message via AIM to D_Ames
It's great as an after run oil. Do NOT use it as an air filter oil. It will break down the foam eventually.
Go to a motorcycle shop and get some foam filter oil. A 16oz bottle is about 8 bucks and lasts forever.
D_Ames is offline   Reply With Quote
Old 03-29-2007, 09:27 PM   #4
A_Stratus's Avatar
I use it for after run oil
Team Express Motorsports
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
A_Stratus is offline   Reply With Quote
Old 03-29-2007, 09:52 PM   #5
AzBobby's Avatar
You make it hard for guys to help you out. first a few days ago you ask if 10w30 is a good filter oil to use and now your want to use a motor oil additive for the same use. almost 20 guys on your other thread told you the exact samething to use and where to buy it. and now your wanting to spend the same amount for this crap that it would cost you to buy the right oil for the right uses.
as an after run oil, this stuff is good as well as 3 in 1 house oil. its not quite as thick and will burn out better when you start you car again.
GO TECH
AzBobby is offline   Reply With Quote
Old 03-30-2007, 07:39 AM   #6
d4man's Avatar
Oh
I have friends like that
Old 03-30-2007, 08:58 AM   #7
SpeedBump57's Avatar
Actually MMO is not really good for some engines as an ARO. Engines that have had crank mods with putty in the crank journal this oil MMO is not good for as it can and will cause the putty to come loose. I use pure mineral oil that you can buy form any drug store and I only do this if I am going to store an engine longer than a few weeks.
USE THE RIGHT OIL FOR THE JOB!
SpeedBump57 is offline   Reply With Quote
mystery stock TeckLancer Radio and Electronics 0 06-22-2008 07:59 PM
What is this mystery tire? leerjet1 Monster Trucks 2 12-04-2007 05:58 PM
FK05 mystery wcalaker Electric On-Road 26 02-19-2007 10:46 AM
Mystery Diff OOde R/C Items: For Sale/Trade 0 02-04-2007 11:05 PM
Mystery Nitro R/C... NuG050 Nitro On-Road 9 08-31-2002 06:58 AM
