Old 03-26-2007, 08:56 PM   #1
LOWGEARED's Avatar
Default STRIPPING ANODIZED ALUMINUM
Stripping Anodized Aluminum
How or what can I use to strip the anodize off my turnbuckles!!!
And stuff like my cooling head ect!......
Or the paint on them what ever that scratchy stuff is its all scuffed up and looks terrible!!!!
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 03-26-2007, 09:16 PM   #2
SupermaxxRich's Avatar
if you want to strip annodizing spray the part with oven cleaner. it'll come right off, rinse with water after 5-10 minutes. and make sure to open some windows
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Old 03-26-2007, 09:35 PM   #3
LOWGEARED's Avatar
Will it weakin my part any?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-26-2007, 09:39 PM   #4
Trader Rating: 35 (100%+)
Yes because you effectively removed the corrosion resistant coating. Aluminum corrodes if ya didn't know already Try this little experiment. Drink a can of pop, then dig a small hole in the Earth, and put the empty pop can in the hole. Now bury the can and pour about a gallon of water on top of the soil. Come back in a week and see how badly that can corroded. BTW, that aluminum can wasn't anodized.
High Desert Raceplace, Grand Jct CO, Sanwa Exzes Plus Stick Radio, Spektrum,Thunderpower 230g, Modified Tri-Nut Novak GTB2, Ballistic 4.5t 550, 5.83lb SCTE Ten, Novak Sentry Brushless Dyno, Crossweight Setup Station, Junsi 20A power supply Icharger 20A Charger,TP610C, 22B, Novak Edge, Novak 13.5, SC10, Havoc Pro SC XDrive, Ballistic 17.5 Matthew Joseph Cordova
mattnin is offline   Reply With Quote
Old 03-26-2007, 09:44 PM   #5
LOWGEARED's Avatar
Ok nevermind??? I'll take your word for it!!! Thanks for the knowledge guys!!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-27-2007, 01:24 AM   #6
dirtracer1's Avatar
ditto the oven cleaner......easy off......and a pair of rubber gloves. you DON'T want that stuff to get on you.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 03-29-2007, 09:32 PM   #7
Diggity's Avatar
Trader Rating: 29 (100%+)
If you go here: anodize stripper You will have to scroll to the bottom of the page to read about the anodize stripper and see the prices.. I have personaly used this stuff and it is the best. You might consider the de-oxidizer also because if you over expose the aluminum in the stripper or use oven cleaner it can leave your parts oxidized (black like) so you will want to use the de-oxidizer to bring back the parts shine! You may also have to re-polish them no matter how you strip them- you can make sure you take your parts out of the anodize stripper occasionaly and rinse them to make sure you do not over-strip them!!
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.teamscreamracing.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 03-30-2007, 12:17 PM   #8
vegaskevin's Avatar
Actually if you polish the aluminum and keep it that way it shouldn't weaken. If you let it continue to oxidize it will continue to weaken. I take the anodizing off most of my cars and it hasn't had any effect on the strength of the aluminum at all. I have raced many types of cars for several seasons with polished aluminum.
Here is a link to my old BJ4
Note:
If you leave the oven cleaner on for too long it will eat into the surface of the aluminum. I recommend you rinse the aluminum often to check the status of the removal.
Note 2:
If you polish the aluminum with a polishing wheel attached to a grinder or something similar, DO NOT WEAR GLOVES! If your glove gets pulled into the grinder your hand is gone! Remember the shop class videos of the guy who lost his hair. If you keep a cup of water near you just dip the aluminum into the water and cool it often.
vegaskevin is offline   Reply With Quote
Old 03-30-2007, 01:01 PM   #9
greased lighting, household cleaner will remove anodizing. says so on the label and i have used it, works great and easy access.
T Green is offline   Reply With Quote
Anodized Aluminum Drift_Buggy Australian Racing 1 12-09-2006 04:06 PM
chassis: machined-aluminum vs. hard-anodized aluminum Dr Gonzo Electric Off-Road 2 11-03-2005 06:50 PM
Aluminum Savage Roller and Anodized Ram Tech Wheels JackinTampa R/C Items: For Sale/Trade 0 08-31-2005 04:49 PM
Gpm Aluminum Steering Setup T4/b4 Blue Anodized adam R/C Items: For Sale/Trade 1 10-24-2004 08:11 PM
looking for Red Anodized Aluminum psychofactor R/C Items: Wanted to Buy 2 01-03-2003 12:43 AM
