Old 03-25-2007, 04:33 PM   #1
aN4rK1's Avatar
Default Old Fuel
Just a quick question about fuel. I have about half a gallon that was purchased about last September. I kept it in my basement, in my bench area, under a table. This room has no windows so it hasnt been hit with sunlight, and my basement is always a few degrees cooler than the main level. I havent moved it since I placed it there since I havent used it. My question is if this fuel spoiled or is it ok to use? thanks
aN4rK1 is offline   Reply With Quote
Old 03-25-2007, 05:16 PM   #2
mremtr's Avatar
That fuel should be fine as long as your basement is dry,and the cap was on tight . It won't be quite as good as brand new but it will work fine.
mremtr is offline   Reply With Quote
Old 03-25-2007, 07:59 PM   #3
schmelme's Avatar
schmelme is offline   Reply With Quote
Old 03-25-2007, 08:53 PM   #4
aN4rK1's Avatar
Yea the cap was on as tigh as i could get it, and it had that insert in it as well. Thanks everyone!
Old 03-26-2007, 12:23 AM   #5
gubbs3's Avatar
I wouldn't worry too much. The biggest problem I see is when I am in and out of the bottle many times. The more it gets opened, the faster it will go bad.
Trying to tune an engine with bad fuel is impossible. You'll wind up chasing the needles all over and it will never run consistently. Running just 1/10 gas truck monthly in the summer usually will let the fuel sit long enough that the last half inch of a bottle will tend to be a bit sketchy. I always much sure I'm not running fuel from the end of a gallon in a main.
gubbs3 is offline   Reply With Quote
Old 03-26-2007, 07:39 AM   #6
Bad fuel works great for lighting the BBQ though. Burns clean and leaves no taste like lighter fluid.
satoch is offline   Reply With Quote
Old 03-27-2007, 04:43 AM   #7
If you had it sitting on a cement floor, you might want to just get a fresh gallon.
8ightScale/CJP is offline   Reply With Quote
Old 03-27-2007, 09:37 AM   #8
aN4rK1's Avatar
It was on carpet, my basement is pretty dry. That fuel going to for bashing anyway.
Old 03-27-2007, 05:40 PM   #9
Old 03-27-2007, 05:44 PM   #10
not wanting to hijack the thread, but is it ok to put any leftover fuel from the tank of your car after your done running it back into the rest of your fuel? Or should one throw it out?
Snipesr82 is offline   Reply With Quote
Old 03-27-2007, 05:58 PM   #11
carbon madness's Avatar
No it is not, fuel from your tank that was used will have containments from the exhaust. So you either have to run it dry or disposed of it properly.
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 03-27-2007, 06:25 PM   #12
good to know. My first Nitro will be here any day so I want to know the do's and don'ts
Old 03-27-2007, 07:46 PM   #13
aN4rK1's Avatar
heres a good tip, the fuel thats usually left over in my tank, i use to was out my airfilter before i use air filter oil.
Old 03-28-2007, 12:37 PM   #14
joe of loath's Avatar
or use leftover fuel as a paint stripper
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 03-29-2007, 04:44 AM   #15
O'Donnell Racing Fuel vs. R2R Fuel SKOT Nitro Off-Road 4 12-28-2007 07:34 PM
Tower Hobbies Power 20% nitro fuel VS Trinity Monster Brew 20% nitro fuel? needhelpPLZ? Nitro Off-Road 1 07-23-2007 06:01 AM
30% fuel motohead24 Electric Off-Road 14 02-08-2006 03:36 AM
<NEW> MONSTER TRUCK FUEL FROM MAXY'S PRO RACING FUEL !!!! <Maxy's> Nelson Racing Forum 0 11-08-2005 10:13 AM
Does O'Donnell fuel make a huge accel. gain on HPI fuel Smoke21 Nitro On-Road 3 05-03-2004 05:44 PM
