Old 03-19-2007, 12:09 AM   #1
Default stock motor for xxxcr
whats your favourite stock motor for the xxxcr. i was thinking of trying the new x stock. any gearing sugestions for a starting point would be much apreciated
mugengreg is offline   Reply With Quote
Old 03-19-2007, 12:17 AM   #2
chris c's Avatar
Trader Rating: 60 (100%+)
c027 from banazi geared at 82 20-21 depends track...
chris c is offline   Reply With Quote
Old 03-19-2007, 01:59 AM   #3
MaTt 93's Avatar
Send a message via MSN to MaTt 93
hi,
The axiom co27 with a 23pinon and stock spur that comes with the kit seems prety good. Also try the axiom x stock with a 21 pinion.
MaTt 93 is offline   Reply With Quote
Old 03-19-2007, 02:44 AM   #4
thanks matt... hey have you's got my yellow handle block splitter and a long handle shovel that i left at the track rebuild
Old 03-19-2007, 09:38 AM   #5
Trader Rating: 14 (100%+)
when using a CO27, don't go any higher than a 21 tooth pinion when using the stock spur, the manual recomendation is to tall.
o.s. power is offline   Reply With Quote
Old 03-19-2007, 07:36 PM   #6
Scottmisfits's Avatar
When using the CO27 I had to go from kit gearing (76/21) to 87/16 and I was still coming off warm. I was oiling the bushings and the drivetrain is very free and no binding.
Scottmisfits is offline   Reply With Quote
Old 03-19-2007, 08:12 PM   #7
kit gearing is 76/23
why would you go to the spur off an mf2?
what brushes and springs are you using?
Old 03-19-2007, 08:33 PM   #8
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
What size is your track? Any pics of the track, that would help alot to suggest gearing, but I would start with 21/78
dgullickson is offline   Reply With Quote
Old 03-19-2007, 09:39 PM   #9
I went to that spur trying to get my motor temps down. I tried the stock brushes and springs and then went to F Brushes with stock springs. There were three of us trying to get the proper gearing and all three of us were within 2 teeth of that. I was using a brushless stock at first, which you're supposed to gear higher, and those temps were just as hot.
Old 03-19-2007, 10:54 PM   #10
MaTt 93's Avatar
Heres some pics of the track
http://www.morcc.com.au/index.php?op...&limitstart=53
http://www.morcc.com.au/index.php?op...&limitstart=50
and yes i think i have those things mugengreg
Old 03-20-2007, 09:29 AM   #11
when you say warm, how warm to the touch of your hand? All motors get warm, does it stink really bad, like you can smell it without having to stick your nose right up to the can? Make sure you are not touching the motor plate, that gets much hotter than the motor itself. Stick with the 76/21 gearing, use reedy 767 brushes with red and purple springs.
Old 03-20-2007, 10:47 AM   #12
nc-hopsing's Avatar
I use Banzai CO27 based stocks in mine. At the Cactus I was geared at 20/78 all weekend. 100 degree weather, motor temps were coming off at around 200 degrees! Car was a rocket. In the early morning practice, temps were in the 180's. We normally run 767's, but were running 766's in the heat. Red and green springs. I run this gearing all the time
Steve Butts
KYOSHO AMERICA.com -Peakmotors.com - kyoshoforum.com - Team SlantEyEs - Hardkore Paint - JBRL Off Road Series - JConcepts.net
nc-hopsing is offline   Reply With Quote
Old 03-20-2007, 04:46 PM   #13
I race pretty much exclusively stock class touring car for my electrics. I know enough about electric motors to make them run. But when we're talking 380* after one run and 250* after the second run with noticably less power, something was wrong. It was time for something to change. The best way to get temps down on a motor is to change the gearing. Did that and holy crap, temps came down.
Just because that gearing works for you, doesn't mean it'll work for everyone. If it works for you, great. It didn't work for me. I didn't ask for my problems to be solved, as I solved them myself. I do thank you for trying though.
PS. When it's three guys, that are having the same issue, using slightly different motor setup's (all CO27's), and all solving it the same way, is it really a problem? It's not hurting anything to change the gearing that low, and it sure beats blowing up motors.
Old 03-20-2007, 10:21 PM   #14
of course its going to have less power after it it 380 degrees, you heat soaked the magnets and glazed over and practically melted the comm. Once that happens the motor is trashed.
When everyone I raced with the past winter all used the 76/21 gearing to perfection, I would have to say it does work for everyone. You must be using a green spring, which will cause a motor to melt down, happened to my mod motor this year.
Old 03-20-2007, 11:06 PM   #15
so has any one used the x stock....it is supposed to be a high reving motor and i would have thought that i would be a good choice on a wide open style of track
Stock Motor Lot w/Trinity case and Much More Motor Mate Racer4Life R/C Items: For Sale/Trade 2 08-19-2007 09:04 PM
$$$ NEW LOSI XXXCR INCLUEDED GTX, BATTERY, SERVO,MOTOR 11-2 ONLY $275 $$$$ HECTICRACER R/C Items: For Sale/Trade 23 02-01-2007 11:51 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
XXXCR,GTX,9000S,3800 Packs,V2 Motor FS bounce R/C Items: For Sale/Trade 12 09-19-2006 06:30 PM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
