Old 03-18-2007, 07:56 PM   #1
Trader Rating: 16 (100%+)
Send a message via AIM to yellowpasta2000
Default What weight oil in XXX-4 on rough track?
What weight shock oil in XXX-4 on rough track? i race at hotrod hobbies in Ca. and the track is rough because they have 1/8 buggys and truggys racing on it too, i have 30 waight shock oil and it seems way to stiff, i have the springs way out loosened and the car wont even bottom out from like 3-4 feet... what shock oil do u guys recomend on ough tracks???
Kunem!
yellowpasta2000 is offline   Reply With Quote
Old 03-18-2007, 08:04 PM   #2
Trader Rating: 96 (100%+)
The only people that know the answer to such a vague question are the people that run there.
K.Copeland is offline   Reply With Quote
Old 03-18-2007, 10:41 PM   #3
sport10's Avatar
The XXX-4 is not a very good buggy in the rough. You can make it do ok but it really never be really consistant. I ended up upgrading mine to an X-5 to get better rough track handling after fighting it for awhile. The X-5 uses the suspension of the XX-4 which is legendary for its rough track capability. The difference is night and day.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 03-18-2007, 11:03 PM   #4
glassdoctor's Avatar
I saw the thread title and first thing that came to mind was...
"change the shock oil? no, don't think that woudl do it. hmmm..... how about change the car to a XX4?"
Seriously I have never owned a XXX4... but it's known that they aren't too happy on rough stuff.
But... do you have limiters that are preventing it from bottoming? What pistons/springs? Mabye it has like #60 pistions??? Probably need more info to help...
My best advice is probably to check out the setups on Losi's site and try one from a rough track...
glassdoctor is offline   Reply With Quote
Old 03-19-2007, 01:53 AM   #5
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
You should look at changing the pistons and springs at the same time
front:
top of shock outside hole on tower, bottom inside hole on arm
black spring
30 wt. #5-6-6 piston
camber link bottom outer hole on tower (shortest)
-1.5 camber
#5 pivot
one-way
cvd's
rear:
top of shock inside hole on tower, bottom inside hole on arm
red spring
27.5 wt. #5-6-6 piston
camber linkoutside hole on tower outside hole on hub
-1.5 camber
-3 pivot (-3 degrees anti-squat)
diff (plastic outdrives w/saver rings)
dogbones
A good site to check out losibk2.com. I own a xxx4 and drive it everywhere.
Cheers
Drift_Buggy is offline   Reply With Quote
Old 03-19-2007, 10:34 AM   #6
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
agreed with others here. Guys I know who ran on a really rough track changed the pistons and went with 27.5 to 25 weight oil all around.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 03-19-2007, 05:56 PM   #7
Trader Rating: 24 (100%+)
Default Piston size spec
Drift Buggy,
You say #5-6-6. Is that a #55 piston (Orange) with 2 holes drilled out to a #56 drill-bit size? Is it that much different than a un-drilled #56 (Red) -- never tried drilling pistons before.
BobWoodhouse is offline   Reply With Quote
Old 03-19-2007, 07:02 PM   #8
You mean a #56 pistion with one hole drilled out to #55.
Yep, that's a 5-6-6...
Old 03-22-2007, 10:17 PM   #9
pserve's Avatar
front:
black spring
-1.5 camber
#5 pivot
one-way
cvd's
rear:
red spring
-1.5 camber
dogbones
Cheers
How do I switch from CVD's to bones in the rear? Which bones & axles do I need to get?
pserve is offline   Reply With Quote
Old 03-22-2007, 10:32 PM   #10
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Even if you put a rough track setup on it. The XXX4 is still going to be difficult to drive when the track gets rough.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 03-23-2007, 07:58 AM   #11
pserve's Avatar
Don't think I need a rough setup for the indoor track, but I would like to know how to go about it anyway.
JP2 Pipe, a little rough but cheap! t4ftracer R/C Items: For Sale/Trade 1 11-05-2007 09:49 PM
best 4wd for rough track ollie2314 Electric Off-Road 16 10-04-2007 05:57 PM
rc12l4: diff is rough Colin85 Electric On-Road 22 02-03-2006 05:54 PM
rough runnings beetlebz Electric Off-Road 3 09-28-2004 01:07 PM
Rough rider gtrcman64 R/C Items: For Sale/Trade 1 08-04-2003 06:40 AM
