Old 03-16-2007, 11:46 PM   #1
joffacn's Avatar
Send a message via ICQ to joffacn
Default 1/10 4WD buggy wheels
Hi
What is the wheel width for 1/10 scale 4WD buggy?
2.2" dia Front and Rear?
Widths F/R?
So what tire sizes are correct F/R?
AE type wheels fit so what other brands will fit?
Thanks Jeff
joffacn is offline   Reply With Quote
Old 03-17-2007, 12:54 AM   #2
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
What buggy do you have?
They are 2.2" and the fronts are wider than 2wd wheels/tires. The rears are the same size though. When buying tires/wheels the front's are just called 4WD tires/wheels - http://www.prolineracing.com/product...th_buggy_tires
Cheers
Drift_Buggy is offline   Reply With Quote
Old 03-17-2007, 01:21 AM   #3
joffacn's Avatar
I am waiting for the D4 to be released. I want to put together a package of all the bits I need to save on shipping costs.
Buggy, spares, wheels, tires, springs, shock oil.
What else?
Jeff
Old 03-17-2007, 01:41 AM   #4
Diff Oil, Paint, Tire Glue, Pinion/Spur Gears
Old 03-17-2007, 07:16 AM   #5
the rear wheels are the same as 2wd rears so proline and losi will both fit. Tamiya and yokomo wheels off the 501x and the bx will also fit but these will require an adapter as i believe they use a hex drive not the pin
for the front you can use losi i have seen these fitted to the d4.
tamiya 501x and yokomo bx both have the same sized drive hex but i think the hex is deeper so this might catch on the hub without trying on a cay i can't confirm.
At the moment proline don't offer a 4wd front wheel but as there is an almost standard sizing this might change as only kyosho and ttech currently use different wheel fittings
for tires just use the versions marked 4wd front by losi or proline. The other option is to cut'n'shut the rears to fit if this is allowed for the races you participate in.
chuckyegg is offline   Reply With Quote
LPR BUGGY WHEELS? allan42r Nitro Off-Road 11 07-24-2008 03:28 PM
1/8th Buggy Tires, wheels NEW! AND...TMaxx/Savage Tires/Wheels. mblgjr R/C Items: For Sale/Trade 13 06-16-2008 10:47 PM
F/S or/T Buggy/MT tires, wheels, buggy engine, pipe, glow igniter, cvec, radio w/ rec playzwtrux R/C Items: For Sale/Trade 1 03-31-2008 10:27 PM
Panther Pythons on Revo Wheels-Crimefighters on Buggy Wheels possom813 R/C Items: For Sale/Trade 17 05-07-2006 08:06 AM
Losi buggy/truck wheels, tourer bodies, bling wheels I'm_Serious Australia For Sale/Trade 0 02-05-2006 06:15 PM
