Old 03-16-2007, 06:30 PM   #1
Default engine break in
iam breaking in a picco .28 when i loosen up glow plug to allow bumb box to turn it over the fuel bubbling up is silver looking . I have ran 3 tanks thru it.1 at high idle 2 at changing rpm never got it hotter than 210. is this normal ?
new2this is offline   Reply With Quote
Old 03-16-2007, 06:33 PM   #2
LOWGEARED's Avatar
Might need to run it rich to flush that out those are metal fragments ... They need to be flushed out! Does it still have pinch at TDC ? flip it over with the GP out and spray WD in it and flush it!!!! Its probably not bad .. it happens!
That would bother me enough to at least get that stuff out
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 03-16-2007, 06:44 PM   #3
i pulled out plug & washed it out it out w/fuel still pinch at tdc
Old 03-16-2007, 06:46 PM   #4
forgot to add running at 2.5 turns richer than factory settings. should i go richer ?
Old 03-16-2007, 06:50 PM   #5
LOWGEARED's Avatar
Is there fuel washing out the pipe?
Whats happening is the parts are fitting and its rubbing off any metal in its way for a good fit !!!!!
You should be good! just keep flushing it if you notice it!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-16-2007, 06:56 PM   #6
PLENTY of fuel coming out of pipe. got nervous when i saw it and did as u mentioned only i used fuel in asyringe fuel line on it to wash out instead of w-d . thanks for reply. very new to this.
Old 03-16-2007, 06:58 PM   #7
LOWGEARED's Avatar
Thatll work to !!!! PEACE
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-17-2007, 12:49 PM   #8
Alltapdout's Avatar
Is it bad if engine looses pinch? @ tdc?
Alltapdout is offline   Reply With Quote
Old 03-17-2007, 03:35 PM   #9
LOWGEARED's Avatar
It looses alot of power so If you have lost it its time for a rebuild or replacement
But if it fires and runs strong dont bother with it yet!!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
How not to break in an engine ! Maximo Nitro Off-Road 4 08-05-2008 10:34 PM
engine break in 37 RACING Nitro Off-Road 10 03-15-2008 03:25 PM
Engine break-in ? acsubie Electric Off-Road 3 05-11-2007 08:42 PM
How do you break in an engine? joe of loath Rookie Zone 12 03-26-2007 04:08 AM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
