Is this ESC any good?
I want to try to race my T3 in the novice stock (27T) class. I need a new ESC. Is this one any good. I know it has reverse but I can shut it off for racing. Has anyone here had this before and would you recomend it?
http://www2.towerhobbies.com/cgi-bin...?&I=LXARP2&P=0 Thanks, |
if you already spend money you should just go ahead and spen 80 on a gts by novak that would be a way better deal.
Haven't heard any feedback on Hitec ESC's. I would recommend a novak XRS for what you are after - http://www2.towerhobbies.com/cgi-bin...&I=LXGNG5&P=ML
Cheers |
Look on ebay (or forums) for a used Novak Cyclone. They will handle any motor you can find and last forever. Cyclones are probably less than $45 now. It's discontinued but still a first class ESC.
The yellow label ones are the oldest & i believe purple is the newest before they discontinued them. |
I agree with the cyclone. Mine has lasted 9 years and has no motor limit like the Hitec.
I agree on the cyclone. Also, if you can find a Tekin G-10 or G-11 esc, they probably are the easiest to setup.
You could also look into a futaba MC230CR or MC330CR. They do 6V BEC, are extremely small, and will handle stock motors or the 330 will do to a 13 turn. I know guys who use the 230CR for 19 turn as well. The esc can be found used for around $25. |
I started racing way back in the day 1988. I have used almost everything out and the best I have used has been tekin products. I got out of the hobby for a while and I guess tekin went under at one point. But I noticed recently they have a website and you can buy some of their older products online. I know you cant beat a g12 or a g9. Very easy to set up.
Do you want one with reverse for when you aren't racing?
Cheers |
cyclone or gts.
hitec
ive used one of the hitec speedys pictured there,but mine was red.it went very well with no problems at all until i ran a 10 turn motor in my stampede with it,then it fried.when i ran a 14 turn with it,it ran with no problems ever.
as for 27 turn, i think that would be fine if you are starting out. i try to dodge seconhand speedies as you never realy know if they are are any good. |
