Old 03-11-2007, 03:46 PM   #1
Default Need help with Caliber 3ps/Reciever
So im kind of in a situation.
I bought an X-5 recently, but my reciever for my 3ps is too big. I need to find a micro receiver (blue). However, the only 3 channels i see say they are for the M8/M11. So i dont want to spend 100 bucks for a receiver and find out it doesnt work.
Am i just SOL and buy a newer radio? Or will the micro blue recievers work? I understand that as long as it is not synthesized, it should work, correct?
My current setup is FM 75Mhz, nonsynthesized.
SupahDave is offline   Reply With Quote
Old 03-11-2007, 04:07 PM   #2
mfishel's Avatar
The Caliper 3PS is still the best handling radio ever. I believe it should work. You may also be able to find a Novak or other aftermarket receiver to fit your needs. Possibly even a new one.
mfishel is offline   Reply With Quote
Old 03-11-2007, 04:41 PM   #3
i picked up a airtronics 92836 75mhz micro fm rcvr on ebay for 35 bucks. ill give it a shot.
Old 03-11-2007, 06:17 PM   #4
I used to have a Caliber and used a blue micro receiver with it. Worked just fine. Have no idea what the receiver number was, but it was a fairly new one. No problems -- just put the crystals in and good to go.
Engineering Without Fear
www.xfactoryrc.com
www.facebook.com/XFactoryRC
YoungChazz is offline   Reply With Quote
Old 03-11-2007, 06:42 PM   #5
thankx chazz! xfactory pulls thru again. Good guys i tell ya.
Old 03-11-2007, 08:31 PM   #6
glassdoctor's Avatar
It will work just fine.
Just a thought... double check the rx to see if it's the old style or the new Airtronics z plug version.
I still have a 3PS laying around... this reminded me of one time I bought a used blue micro rx.... and didn't know it was the new (standard) z plug style and I smoked it the first time I hooked it up. (polarity is backwards on the old stuff)
Hope I didnt' confuse you....
glassdoctor is offline   Reply With Quote
Old 03-11-2007, 09:44 PM   #7
ill check into it. im pretty sure all new rx's use z plug. does this refer to the polarity, or plug type?
Old 03-11-2007, 09:51 PM   #8
polarity... z plug is just what they called it when they switched to the standard neg/pos/signal like everyone else.
It has been several years now... but the 3PS was old-school so your stock 3PS rx should have the old airtronics pos/neg/signal setup.
no biggie... just a heads-up
Old 03-11-2007, 10:58 PM   #9
its the old style. Ill make sure i research it before i install it. If i remember correctly, I had to swap pos & neg on my novak gtb to work with my old reciever.
Thanks for the heads up.
Old 03-16-2007, 05:16 PM   #10
Trader Rating: 50 (98%+)
Default reciver
i have a hi tec i know works my sone uses it with his 3ps.
bj4racer25 is offline   Reply With Quote
Old 03-18-2007, 05:31 AM   #11
Yes just switch the POS and NEG between the old airtronics receivers and the newer blue airtronics receiver. The new receivers have the POS in the center position.
plumslow is offline   Reply With Quote
Airtronics 3P Caliber with reciever monsaas R/C Items: For Sale/Trade 1 02-02-2007 04:47 PM
Airtronics Caliber 3P and Novak XXL reciever evostyle R/C Items: For Sale/Trade 3 12-03-2005 07:40 AM
Airtronics Caliber 3Ps KevanB R/C Items: For Sale/Trade 11 02-05-2005 07:47 PM
Airtronics Caliber 3P Help Griffin Electric On-Road 7 03-03-2004 07:14 PM
looking for caliber howard hudson R/C Items: Wanted to Buy 0 11-11-2002 08:31 AM
