Old 03-10-2007, 11:09 AM   #1
Default Swapping rotors on Velociti motors
May be a dumb question but cannot find an answer. Can you swap a 4.5 sintered rotor into a 7.5 motor? I know you can swap rotors on brushed motors, but am wondering if you can for brushless as well.
Thanks.
SupahDave is offline   Reply With Quote
Old 03-11-2007, 03:34 AM   #2
Send a message via AIM to jg727211
I asked the same question & Novak's response is below in bold. BL & Brushed are the opposite when you want more/less power (can vs. armature (rotor)).
The “winds” in a BL motor are in the can. They make up whats called the “stator”. The Rotor, is the armature. It’s the magnet and the shaft that sticks out. Changing rotors has an effect on power, but not like changing winds does.
I think basically in comes down to:
-Changing the armature in brushed is where the power comes from because that's where the winds are. A can is a can for the most part.
-Changing the can for BL is where the winds are so that's what you would change for more/less power. A rotor is a rotor?
Bottom Line: Yes you can switch rotors but you won't see much improvement.
jg727211 is offline   Reply With Quote
Old 03-11-2007, 05:20 AM   #3
It is the same indentical rotor in all Velociti motors. Yes it is the same and well worth the change too. Alot cooler temps on the ESC and the motor.
Craps is offline   Reply With Quote
Old 03-11-2007, 03:26 PM   #4
Makes sense. I never tore one apart to look. Figured if i would have it would have been self-explanatory. The main reason was i believe i saw different sintered rotors for each model of BL motor.
Thanks for clearing it up!
Now i have to find a 5.5 to put in the x-5! Woo [email protected]
Novak Bonded Rotors for Brushless Motors dr_hfuhuhurr R/C Items: For Sale/Trade 2 01-28-2008 07:56 AM
Xray Fk05,Velociti 3.5R System with GTB,Velociti 4.5R,And More ctd R/C Items: For Sale/Trade 12 07-30-2007 08:05 AM
Xray Fk05,Velociti 3.5R System with GTB,Velociti 4.5R,And More ctd R/C Items: For Sale/Trade 0 07-23-2007 06:04 PM
For Sale Novak Velocity rotors for Novak Brushless motors!! Marcos.J R/C Items: For Sale/Trade 61 01-30-2007 10:57 AM
swapping willabong Australia For Sale/Trade 0 06-10-2006 06:55 AM
