Old 03-06-2007, 05:12 AM   #1
Default HYPER 7 TQ - PBS front end upgrade?
Will the PBS arms and other gear bolt straight onto the Hyper 7 TQ mounts?
I want to do this as the TQ knuckles keep stripping the thread and I loose upright/C-Hub screws during races..
Can I just buy the arms, uprights, and bolt on?
GSRace is offline   Reply With Quote
Old 03-06-2007, 11:16 PM   #2
Anyone done this?
Old 03-07-2007, 09:49 AM   #3
basically you need the upper and lower arms along with the uprights. You shouldnt have any problems fitting everything on. Are you stripping the knuckles?
Genius is offline   Reply With Quote
Old 03-08-2007, 12:39 AM   #4
MadRacer's Avatar
Trader Rating: 33 (100%+)
You are better keeping with the c hub front. It handles the rough much better and has more steering..
Boondal vintage Tamiya's
https://www.youtube.com/watch?v=vtmCddStNyM
QLD State Titles winner in 6S EB CAT
MadRacer is offline   Reply With Quote
Old 03-08-2007, 12:57 AM   #5
Thanks Genius and MadRacer.
I am stripping the lower upright threads, and loosing the screws during races. I've tried tight, not overtight, and tried red and blue loctite.
Our track has been redone, so the jumps might be a little easier on the landing.
This is the 2nd time I've heard stick with C-Hubs, but my mate with the PCR has no problems with the PBS setup.
Old 03-08-2007, 05:51 AM   #6
The reason I ask is because the TQ comes with a different version knuckles from the older hyper7 models, these are supposedly lighter and thinner. Some batches did have a tendency to strip. you might wanna check for the old version knuckles, or get the PCR knuckles, or get a pair from a hyper 8 which should fit if im not mistaken. I ran the c hub version for 3 years, loved it!
Old 03-08-2007, 06:10 AM   #7
Yeah I heard there were at least 2 versions, newer had a bit of bracing to stop outright breakage..
when you say PCR knuckles, aren't they PBS? like my mates PCR.
and yes I haven't ran it for months, but I loved it too! (dun worry it was doused with after run, and is very nice inside the block)
Old 03-08-2007, 06:33 AM   #8
PCR made knuckles for the hyper 7. the pcr-pbs is just a different version of the hyper 7. i attached a picture of the pcr knuckles
Old 03-09-2007, 05:09 AM   #9
ahh good stuff, are they less prone to breaking and/or stripping the threads than the TQ silver alloy knuckles?
Will they fit the TQ C-HUB?
Old 03-09-2007, 05:12 AM   #10
8ightScale/CJP is offline   Reply With Quote
Old 03-10-2007, 09:35 PM   #11
they should fit in without any problems at all. from my experience they're very solid. they havent failed on me yet.
Old 03-11-2007, 03:10 PM   #12
amain's Avatar
honestly i would go with the pbs suspention. it a good setup and you cant bash it beacuse mugen mbx5 usues it and is a amazing buggy with many big wins under it belt. so... . i am pretty sure u can actualy get a conversion kit form ofna that has every hting you need.
amain is offline   Reply With Quote
Old 03-11-2007, 05:37 PM   #13
MadRacer's Avatar
I raced my hyper pbs pro for year.
The problem with the hyper pbs system is that it does not give enough steering lock.Yes the mugen has a good pivot ball set up as does my TTR S3 . Where these set ups seem the same they are not. The main area is the eye where the ball sits in. On my TTR this is a lot different. The hyper uses more of a cage set up in the socket. If you look at the different versions you will see.
Rule of thumb is a pbs is slightly better for a smooth fast tracks and a c hub is better for rough tracks. Kyosho have never built there buggys with a pbs. I now have a Hyper 8 and handles way better with a c hub.
Anyway just my experiance im not knocking any syestem its just the reason why i sold my 7 pbs. The Hyper 8 is great.
NEW UPGRADE BODY WRAP FOR RC8. HYPER FLAMES-BLUE Pete Taulbee R/C Items: For Sale/Trade 3 01-27-2008 07:45 PM
Hyper 21 carb. upgrade cweb Electric Off-Road 5 10-04-2006 12:27 AM
Hyper 7 pro with yannik upgrade kit jimstoyz R/C Items: For Sale/Trade 9 01-20-2006 11:00 PM
Hyper 7 cnc front knuckles/front upper arms trashedmaxx R/C Items: For Sale/Trade 2 09-17-2005 01:28 PM
950-R Front End Upgrade Kit Accord Nitro On-Road 8 12-04-2003 04:30 PM
