JConcepts Thread
#9241
Tech Legend
Trader Rating: 51 (100%+)
PW you don't by chance have any of the tire brushes around I could buy for one of my customers or a possible idea when they will be available again? Those seem to be a hot item. Have to say they do work great.
Brian
Brian
#9242
The tire cleaning brush or the yellow tire/saucing brush? I don't have any extra laying around, but the tire cleaning brushes are scheduled for April. Not sure about the yellow Dirt brushes
#9243
Tech Legend
Thanks PW for the quick reply. It was the tire cleaning brush. Actually I personally have both and they work great. Funny but the bristle softness/hardness is just right on those things. Not too soft and no too hard.
#9244
Believe it or not, we actually tested the bristle stiffness...LOL We had 3 different ones to choose from
#9245
Any news / ETA on the new B6 aluminum front ball stud mounts?
#9247
#9248
Paul, just wondering if you could explain when it's a good time to n use spacebars over the dweb on clay? I use dweb now just curious to try spacebars.
#9249
Unfortunately I don't have much experience with Space Bars or clay tracks, but what I have experience is this. The Space Bars have less side bite and take longer to break-in, but seem to be faster once broken-in. Dirt Webs seem to be a safer tire to run with a bigger tuning window.
#9252
Same location (Lake Park), what do you recommend for 1/8 e buggy?
#9253
Can you explain a little how the compound affects traction in wet vs dry? I was under the impression that the tread is what affected traction in different terrains and the compound (soft through hard) basically was how pliable the tire was in that terrain.
I see Reflexes come in long wear as well. If I am not a hard core racer and wanted tires to last a little longer could I get away with long wear reflexes?
Looks like Reflexes are all out of stock on your site but I'll wait
#9254
The R2 will certainly last longer and work great in the warmer/drier conditions.
