Old 03-05-2007, 06:34 PM   #1
bxpitbull's Avatar
Default HELP WITH GEARING FOR HOT BODIES LIGHTNING STADIUM
Heres the dilema...bought the hardened diff for my Hot Bodies lightning. As you guys know, the lightning comes with spiral gears both pinion and ring gear for the differential. Now, here is the problem. The hardened diff is straight cut. Wouldnt be a problem...if they sold a straight cut pinion with the same number of teeth!. The ring gear, both spiral and straight are 43 teeth, with the spiral pinion being 10 teeth. The Hot Bodies straight cut pinion is 13 teeth! Will this throw off my internal gear ratio? HELP!?!?!?!
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 03-05-2007, 09:24 PM   #2
Yes that will mess up the ratio big time. I would see if the Hot bodies Stadium ring gear will bolt on the diff case. If so then your in luck. It sounds like you got a Buggy diff and not the Stadium diff that is all. The diffs are the same between the two only difference is the ring gear.
redneckracer197 is offline   Reply With Quote
Old 03-06-2007, 07:59 AM   #3
bxpitbull's Avatar
Default Thats what I thought
I tell you....I thought the very same thing. What threw me off was the "techie" at HPI. He told me he made the conversion and he noticed no change in his lightning! That struck me as odd and really threw me for a loop. Man, they need to get their heads out of their a$$e$ over there! Thanks.
Old 03-06-2007, 07:40 PM   #4
A friend of mine tried it once and told me that it wasn't a good idea. He said he lost a ton of his off the line power. Now if you were running a tire like the Komodo LP then it wouldn't be an issue really.
Hot bodies Lightning Stadium 2 Pro ThomasGorski Nitro Off-Road 37 02-03-2009 03:51 PM
Hot Bodies Lightning Stadium domestictuner44 R/C Items: For Sale/Trade 15 10-30-2007 08:58 AM
Hot Bodies Lightning Stadium 10 P2 R/C Items: For Sale/Trade 6 10-15-2007 08:00 PM
Hot Bodies Lightning Pro R Stadium 1/8th braeden R/C Items: For Sale/Trade 0 01-28-2007 09:30 PM
Hot Bodies Lightning Stadium Pro Chase Electric Off-Road 3 02-02-2005 11:11 PM
