Tips on gluing buggy tires? >
Old 03-03-2007, 04:16 PM
Suspended
Trader Rating: 10 (92%+)
Default Tips on gluing buggy tires?
Anyone have any tips on mounting 1/8th scale buggy tires? Im a buggy tire gluing virgin, could use all the tips I can.
4u2nv is offline
Old 03-03-2007, 04:22 PM
sharkman's Avatar
Trader Rating: 18 (100%+)
Clean the tires and wheels before you begin. There is usually a mold release lube on them and the glue bond will be weak. A little rubbing alcohol will take care of it.
Also make sure you fit the tires on the rims and make them right before you glue.
sharkman is offline
Old 03-03-2007, 05:04 PM
Clean the tire and rim beads, then clean the tire bead. I use the cheap brake cleaner from Wal-Mart. Then before you mount the tire on the rim, clean the tire bead. Basically, clean the tire bead really, really well.
Manning is offline
Old 03-03-2007, 05:11 PM
http://www.youtube.com/watch?v=_vmWfFyh668&eurl=
Apexs is offline
Old 03-03-2007, 06:17 PM
Suspended
VERY awesome vid. Helped a ton. Thanks!!!
4u2nv is offline
Old 03-03-2007, 06:26 PM
yeaklet4's Avatar
Trader Rating: 34 (97%+)
i just did up 6 sets of tires and using elec tape i think is the best beacuse you can get it very tight.
yeaklet4 is offline
Old 03-03-2007, 08:48 PM
Suspended
I used one of the "Live Strong" rubber braclets. Seemed to work pretty good.
4u2nv is offline
