Old 03-02-2007, 05:47 AM   #1
xxx-ntad2 racer's Avatar
Trader Rating: 24 (100%+)
Default o.s. vg pipe choice.
i've heard a lot of guys saying the jp-2 works good with this motor. but also heard the ofna 086 works fine too and stumbled around this:
http://www.horizonhobby.com/Products...rodID=DYNP5005
dynamite's 086 pipe.
i was wondering if this pipe works good or will work fine on my vg.
thanks!
Hobby Pro USA
www.Hobbyprousa.com
xxx-ntad2 racer is offline   Reply With Quote
Old 03-02-2007, 06:58 AM   #2
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
Dont even waste your time.
O.S. Motor's work best with O.S. pipes.
You will spend more but you will get more mileage per tank(if racing) and it will have it's best power.
O.S. 2050 is the way to go on this motor.
If you simply dont have that much to spend and not a racer.
JP-2 would be my 2nd choice.
Les
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 03-02-2007, 08:14 AM   #3
thanks for the info. i'll check that pipe out.
btw, i'm a racer doing some club racing. problem is is that i'll be racing my ad2 for most of the time and my hyper 7 will be my runner up. so i don't need to spend alot of money on a pipe for a few races. but thanks for the info.
Hobby Pro USA
www.Hobbyprousa.com
Old 03-02-2007, 03:09 PM   #4
dirtracer1's Avatar
there's really no good reason to buy a pipe that costs as much as your motor.....get the jp-2 pipe.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 03-02-2007, 10:32 PM   #5
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
I race, can afford watever pipe i want and run a JP2 on the vg. It works great and I have run 11 minutes at race pace.
infanterene is offline   Reply With Quote
Old 03-02-2007, 10:38 PM   #6
I dont mean to derail your thread but what temp do you guys run you vg at. I have heard that this engine likes to be cool but mine seems to run better hot. Thanks. Also I have the jp2 pipe with mine.
indysu[ra is offline   Reply With Quote
Old 03-02-2007, 11:32 PM   #7
Trader Rating: 66 (100%+)
Default runs hotter
I tried to run it cool but its a bit slow @ 220. REally no power. At 250 its good. Also remember the head is a bit small. Thats with smoke trailing too and no lean bogging.
Tmachine is offline   Reply With Quote
Old 03-03-2007, 08:57 PM   #8
money is not really a problem. i've just heard alot of guys say the ofna 086 pipe works well with the vg and was wondering if the dynamite 086 is basicly the same pipe?
thanks for the info guys!
Hobby Pro USA
www.Hobbyprousa.com
Old 03-08-2007, 08:17 AM   #9
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
I wonder the same thing, is the 086 a good pipe for the engine?
Also, does anyone feel that you should replace the head on the VG with something bigger or is this a non issue?
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 03-08-2007, 08:48 AM   #10
dirtracer1's Avatar
in florida where i'm at with the heat and humidity.....sometimes. in fargo, i wouldn't think so. run the head it comes with and a jp-2 pipe.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
Old 03-08-2007, 08:52 AM   #11
tex1's Avatar
Send a message via Yahoo to tex1
Post
The 086 will give you good power at the sacrafice of run time.
Les' suggestion of the 2050 by OS is an incredible match and my favorite. It cost a lot and has been discontinued. Don't know why. It is also a little lighter than the JP pipes.
The VG is a bottom end motor. It likes mid to top end pipes and filles them well.
I have found the JP3 to be close to the OS 2050. You still get the mileage and the top end ofthe 2050 but it cost about $10 more than the JP2.
The new Dynamite pipes are real good. The mid and top end pipes are the ones I would look at here. They have the good stingers and look great.
I run the 053 on my OS and it runs great.
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 03-08-2007, 08:59 AM   #12
dirtracer1's Avatar
.....unless it was replaced with the 2060.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
Old 03-08-2007, 09:05 AM   #13
tex1's Avatar
I wonder......
I just put the 2060 on my car. I don't know yet but they look and are designed completly different. 2050 uses short header. 2060 uses the long one. 2050 is designed on bottom end 3 chamber principles and the 2060 is a two chamber smooth flow design.
I would think they would need something different than the 2060. Maybe they just found a way to make it look better. The 2060 looks much better and more refined.
Who knows???? We can not find anything on it with OS.
TEX
www.indyrcworld.net
(972) 271-4844
Old 03-08-2007, 10:35 AM   #14
Tech Legend
Cain's Avatar
Here we can get the heat, but no real humidity.
Old 03-08-2007, 05:17 PM   #15
dirtracer1's Avatar
still.....i'd think that you'd be fine with the stock head. if however, after you get the motor and you think it's over temp, check to see if your not leaned out too much, check the drive train for binding, or anything else that would load up the motor.
if you still think you might need a aftermarket head, so far, the only one i know of is the king headz head. they have them in silver, blue and black.
http://www.amainhobbies.com/product_...ducts_id/11533
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
Sirio S27 Pro pipe choice cusco Nitro Off-Road 0 08-05-2008 05:13 AM
best pipe choice for the werks racing B3 motor... xxx-ntad2 racer Electric Off-Road 5 03-30-2007 07:33 PM
Pipe Choice... *_DeckeR_* Australian Racing 5 04-20-2005 03:28 AM
Pro 4 v R3 v Yok CGM - your choice? el73 Malaysian R/C Racers 75 05-16-2004 08:09 PM
New To R/C Car Choice alp2 Rookie Zone 15 05-10-2003 06:48 AM
