Old 05-06-2008, 02:59 PM   #361
Glad you guys are having fun with your New Math. Hope to see some of you west coast guys at the Shoot-Out.
Engineering Without Fear
www.xfactoryrc.com
www.facebook.com/XFactoryRC
YoungChazz is offline   Reply With Quote
Old 05-13-2008, 03:38 AM   #362
shy@klp.no's Avatar
Finally got to test mine... and I could hardly believe it!
-Steering
-Grip
-Bump handling
This really is "legal cheating"!!!
And one more thing! It was actually more fun than driving a 4WD - you can be as aggressive as you like!
X-Factory rules!
Life's too short to go slow! www.ymr.no
shy@klp.no is offline   Reply With Quote
Old 11-19-2008, 03:13 AM   #363
Dal
Dal's Avatar
Send a message via Yahoo to Dal
HI Everyone,
I'm new to the X-Family,
Just recieved my X-6 kit in the mail.
Does anyone know why the motor sits on the side it sits on?
I mean oposite (left and right speaking) to all other cars.
It seems that if it just turned to the other side (180 degrees) the 4th gear would not be needed.
Also, what about getting rid of the 2 idler gears completely, that would make it go forward as well while still sitting in the same X6 position.
Maybe the direction of the motor helps with the handling?
any ideas?????????????????????/
Dal is offline   Reply With Quote
Old 11-19-2008, 06:00 AM   #364
RURC's Avatar
Originally Posted by Dal View Post
HI Everyone,
The reason for the motor flip is for the handling. In the early X6 they did not flip the motor. Now this flip is putting the rotational forces to work for the chassis to increase the handling of the car. I have an old one and a new one and I have to say that I am not a good enough driver to really get a consistent difference between the 2. But I know others that do see that the new lay out is better.
Michael
3 Phase Racing///Schumacher///Max Amps///TigerMoth Racing
Team Tekin ///FMC lipo chargers///Neu Motors///Multiplex
McAllister Racing///Lauterbacher
Real racers dont wear boxers.
RURC is offline   Reply With Quote
Old 11-19-2008, 07:17 AM   #365
SpeedyDad's Avatar
Moving the motor allowed the buggy to take advantage of the torque created by the motor. This translates to better acceleration and better control in the jumps.
You can't get rid of the 2 idler gears. The motor would be too close to diff and sit right where the outdrives would go.
Chris Krieg
X Factory SCX-60 chassis #00 & SCX-60CF prototype #1(both retired)
X Factory X-6, X-60CF (prototype #2), SCX-60CF
X Factory - www.xfactoryrc.com
Stickit1racing - www.stickit1racing.com
SpeedyDad is offline   Reply With Quote
Old 11-19-2008, 10:39 AM   #366
I believe it is a ROAR rule the trans has to be a minimum 3 gears? schumacher used to have a 2 gear/belt trans and somebody made one for the rc10, many years ago????
DAVE BERNATH is offline   Reply With Quote
Old 11-19-2008, 12:54 PM   #367
Paul_Sinclair's Avatar
Send a message via AIM to Paul_Sinclair
Everyone's right on, the motor is oriented the way it is so that it's torque helps the car gain traction on acceleration as well as to make the pitch of the car more controllable in the air. You could not do this without the idler gears because it becomes impossible to get a good final drive ratio, as the spur gear would have to cover up the outdrives (or you would need a massive diff gear which would reduce ground clearance, XXX4 style).
Dave - That's something I've heard from other people as well, but there is nothing in the ROAR rules stipulating how many actual gears need to be in the transmission. They simply say it must be a single-speed transmission, ie, no 2-speeds devices.
X Factory R/C - Viper R/C - Futaba - Darkside Designs - Lunsford - MIP - B Fast Performance Diff Parts
Paul_Sinclair is offline   Reply With Quote
Old 11-19-2008, 05:07 PM   #368
Paul, for a time line we are talking the early 90's when this came out, I am sure the rules have changed. But from what I was told the there was a distinct advantage with the schumacher belt trans. Unfortunaly todays motors and batteries would probably shread a belt. This was back in the 1200mah SCE era. I just dated myself again!
Old 11-23-2008, 08:17 PM   #369
Default Lipo Setup
Anyone have a setup for x6 with lipo.
Jimmy G is offline   Reply With Quote
Old 11-23-2008, 09:04 PM   #370
SpeedyPenguin's Avatar
For Losi shocks:
http://2wdrc.com/pdfs/Setup-Sinclair-4GearLosi.pdf
For AE shocks:
http://2wdrc.com/pdfs/Setup-Sinclair...Associated.pdf
X-Factory, Hobby Action, Jconcepts, Stick it 1 Racing, B Fast
SpeedyPenguin is offline   Reply With Quote
Old 11-25-2008, 05:27 AM   #371
PHIL700XCSP's Avatar
I'm definitly ready for the x-60.Any new news??
PHIL700XCSP is offline   Reply With Quote
Old 11-25-2008, 05:47 AM   #372
gone banana's Avatar
Trader Rating: 14 (100%+)
it will be by the end of the month 2wdrc. for inf.
gone banana racing skin`z -
team c racing t8e team c racing t8te
team c racing tm2 team c racing tm2 stadium truck
team c racing tm2sc team c racing ts4 pro
airtronics mt4 with grid rc drop down wheel
gone banana is offline   Reply With Quote
Old 11-28-2008, 07:45 PM   #373
I've been running this set-up for the last few months and its really been working well, I've been happy with it not only at Hot Rod but also at the indoor track in Nashville, and the indoor track at CRCRC.
http://www.2wdrc.com/pdfs/Setup-Sinc...HotRod2008.pdf
Old 11-28-2008, 08:42 PM   #374
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
Glad to see XFactory still going strong! Thought I would stop in to say hi, .
Keep it up!
...Jim
W.E.D.
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 12-01-2008, 11:43 PM   #375
Dal
Dal's Avatar
Has anyone had a kit arrive with a gronked up part?
I got my kit and the wing mount was bent, I sent an email with a pic of the suspect part to try and get a replacement,
I get no reply from the xfactory.
I am keen to run the car, but without a wing, its pointless.
x5 xfactory gone banana R/C Items: For Sale/Trade 1 09-05-2008 06:45 PM
WTB: XFactory X-5 or X-6 tarzan5 R/C Items: Wanted to Buy 4 09-02-2008 06:18 PM
x 5 from xfactory gone banana R/C Items: Wanted to Buy 0 09-02-2008 04:14 PM
Xfactory X5 frank p R/C Items: For Sale/Trade 6 10-11-2007 06:49 PM
