Old 01-14-2008, 03:59 PM   #301
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by GroffBall View Post
I should be there next weekend. The scary part is if I had brakes I might have had something for Robert in the main. My car was good for low 19s on treads with breaks without brakes 20.0 was all I could muster. I hope to have a new motor for this weekend. I want to have jimmy order me a new orion because to me the feel of the orions is just better.
Cool. Your car was good. I hope everything goes well and if it does I will be racing with another new setup to try but this time for slicks. I have the new stuff I need on order. Jim got my other stuff in today so I need to make a trip down Friday to get my parts.
ST Racing Concepts (STRC)
Old 01-20-2008, 12:35 AM   #302
Originally Posted by sght4 View Post
I race stock buggy were I run, and right now I have a 81 tooth spur and 20 tooth pinion and after a 5 min. race my motor is allmost 200 degrees, what is a proper gearing for a small indoor track.
Just to let you guys know I got this problem solved, I tried sevaral different gearing setups and went back to the 81 tooth spur and 20 tooth pinion and mounted a small novak fan above the motor and went from 200 degrees to about 145 degrees so the fan did wonders.
sght4 is offline   Reply With Quote
Old 01-27-2008, 06:47 PM   #303
Trader Rating: 67 (100%+)
Default Fan
Could you share a pic of how you mounted the fan. I have the new four gear and it has two "mystery" holes in the plate that I understand will be for a fan mount. I thought maybe your set up might help to see how it might work. Thanks.
nutz4rcyktw is offline   Reply With Quote
Old 01-27-2008, 08:18 PM   #304
How do I attach pictures. I got it.
Old 01-27-2008, 08:55 PM   #305
What I did was use a thin piece of aluminum and bent and cut it until I got what I wanted, I also drilled and taped one new hole in the motor plate, I hope you can see what I did by the pictures.
X6 XFactory in 07-2008_0127x-60022.jpg   X6 XFactory in 07-2008_0127x-60023.jpg   X6 XFactory in 07-2008_0127x-60024.jpg   X6 XFactory in 07-2008_0127x-60025.jpg
Old 01-28-2008, 08:11 AM   #306
Default Pics
Thanks for the excellent pics. This gives me food for thought for what I want to do. I am new to the X Factory family and appreciate the help.
Old 01-28-2008, 01:21 PM   #307
I have only had mine for 4 weeks now, I love it.
Old 01-28-2008, 06:22 PM   #308
Default Good News
Glad to hear you like the car. I am running the 4 gear tranny, new conversion kit, and Losi shocks front and rear. I used Paul's setup for the 4 gear and am anxious to try it out.
Old 01-28-2008, 06:57 PM   #309
Suspended
Thumbs up
anybody know the results from the winter rage ! how did kinwald do?
losidriver70 is offline   Reply With Quote
Old 01-28-2008, 09:05 PM   #310
Brian won mod buggy and mod 4WD with the X - 6 and X - 5 respectively. He did not enter truck.
Engineering Without Fear
www.xfactoryrc.com
www.facebook.com/XFactoryRC
YoungChazz is offline   Reply With Quote
Old 01-29-2008, 08:36 AM   #311
Suspended
Thumbs up
thank you!
Old 01-29-2008, 01:41 PM   #312
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
he was at my track this weekend, I took some good shots of his cars, I'll post them up tonight.
He won 2w and 4w mod classes. It was really fun to watch him race and pick his brain about setups and stuff...really nice guy!
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 01-29-2008, 01:51 PM   #313
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Not only was he fast and a great person to talk to about rc or anything else, he had the cleanest looking cars I have ever seen. The modifications and custom work pretty incredible and definitely thinking outside the box.
Cant wait to see the pics!
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 01-29-2008, 08:52 PM   #314
Suspended
Thumbs up LOOKED LIKE A GREAT RACE MAYBE NEXT YEAR FOR ME!
just got done watching videos of the winter rage. i like the up the wall ramp backside thing id be burning rubber around that on fools!
Old 01-29-2008, 10:05 PM   #315
GRRRRRR!!! I had like 50 pictures of BK's X6 and I can only open 5 of them DAMMIT! I can't for the life of me get the rest of them to open up...(insert choice word here) Futher Mucker!
Anyway, here's the 5 I could open...
to describe it in words:
-Xray captured ball ends throughout
-One-Off Carbon Fiber Front/Rear Shock towers
-One-Off Carbon Fiber Motor Plate
-One-Off Carbon Fiber Battery Strap
-Lunsford quick change shock mounts used as battery strap mounting posts
-Losi CR rear hubs
-Xray TC 64 Pitch gears
-Chassis has a hole milled in the side that the very tip of the on/off switch pokes out through so you just barely lift up the body and the switch is right there on the side of the chassis
-Orion 3200 Lipo mounted sideways in chassis and never comes out...ever
-Battery slots in bottom of chassis are filled with solder...yes solder, he found that solder weighs more than lead so he is dripped solder into an extra chassis as a mold and uses those as chassis weights.
-All tierods, shocks, drivelines were basically shorted out in some fancy anodizing method that turned all those parts to a gunmetal color
-Capacitors, wires, OnOff switch, PT, all blacked out with black rubber shrink wrap
That's all I can remember off the top of my head, his pit was by far the cleanest I've ever seen and remained the cleanest throughout the week.
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
x5 xfactory gone banana R/C Items: For Sale/Trade 1 09-05-2008 06:45 PM
WTB: XFactory X-5 or X-6 tarzan5 R/C Items: Wanted to Buy 4 09-02-2008 06:18 PM
x 5 from xfactory gone banana R/C Items: Wanted to Buy 0 09-02-2008 04:14 PM
Xfactory X5 frank p R/C Items: For Sale/Trade 6 10-11-2007 06:49 PM
