Old 02-25-2007, 06:04 PM   #1
Default GT2 Questions
Hey Fellas,
I did a search on the forum and came up with a few options, but not many, so I was wondering if you guys could post some different steering servos (and model numbers) that are capatible with the AE GT2.
Also, with a new steering servo, does the power source need to be upgraded? Right now, I'm just using off-the-shelf Duracell batteries. And I can continue using the same radio that came with the truck, right?
Thanks, and any help is greatly appreciated!
Fred
Fred30 is offline   Reply With Quote
Old 02-25-2007, 06:10 PM   #2
Trader Rating: 14 (100%+)
any standard size servo will fit. 90% of the servos available are standard size. An upgrade of batteries would be a great thing to do, orion 1600 marathon packs work great for me.
o.s. power is offline   Reply With Quote
Old 02-25-2007, 06:35 PM   #3
What about the specs on this servo:
Torque: 85 oz/in at 6V
Speed: .15 sec/60 at 6V
Gears: metal
Compared to the stock servo:
Torque: 41 oz/in
Speed: 0.19 seconds at 60 degrees
Gears: metal
Will it be much faster / better?
Old 02-25-2007, 07:16 PM   #4
kuzo's Avatar
Send a message via MSN to kuzo
Gears: metal
Torque: 41 oz/in
Gears: metal
It would absolutely be faster and with twice the torque as long as the stock servo specs are at 6V. What is the manufacturer/model you listed?
kuzo is offline   Reply With Quote
Old 02-25-2007, 07:44 PM   #5
Kevin Boyle's Avatar
I run Airtronics
94357Z ERG-VR High Speed Servo for the steering and 94731Z Contest Aircraft & Heli Servo for the throttle (sp)
Hope that helps... here is the link to their site
http://www.airtronics.net/ATX_servos.htm
Later
Kevin Boyle
Kevin Boyle is offline   Reply With Quote
Old 02-25-2007, 07:54 PM   #6
Thanks for the responses, guys.
The one I listed is a JR Z590M, listed at $39.
For $10 more, I can get the Z650M:
Torque: 142 oz in @ 6V
Speed: .17 sec/60 degrees @ 6V
Gears: Metal
There's no volt specs on the stock servo, which is the AE S1903MG.
I see the torque ratings on the JR's are much higher, but the speed is only .02 faster than the stock AE, which is .19.
I don't know much about servo's, but that doesn't seem like much of a difference in how fast the transition from left to right will be. It seems like the torque rating would apply to a larger, heavier wheel.
Or, do I have this all wrong and the transition from left to right will in fact be much faster?
Thanks for any input.
Fred
Old 02-25-2007, 08:03 PM   #7
Fred30,
For 10th scale racing 100 to 125oz is perfect, anything more is over kill. The transit time is also key when you turn the wheel you want it to be there. I know servos are not cheap but you get what you pay for... spend a little more and you will not be disapointed.
Later
Kevin Boyle
Old 02-25-2007, 09:06 PM   #8
Originally Posted by Kevin Boyle
Fred30,
Later
Kevin Boyle
Any recommendations? The problem is, I have no idea which manufacturers I should be looking at. Also, what kind of transit time should I be looking to upgrade to?
Also, does switching from a 20T clutch bell to a 21T have a big impact on the top-end?
Old 02-25-2007, 09:35 PM   #9
Trader Rating: 42 (92%+)
A 21t will give more top end good if you run on an open track
with 21t you will lose some torque.
Indoors I usally run 19,20t to be able to clear technical jumps
I would only use 21 on big track
as for servo my steering and throttle are both like .06
truck reacts just like electric
icemandolmite is offline   Reply With Quote
Old 02-25-2007, 10:11 PM   #10
Cool, thanks.
By the way, does anyone know if there are upgraded clutch shoes available for the GT2, perhaps aluminum?
Old 02-25-2007, 10:45 PM   #11
you dont need aluminum, ae makes 1.1,1.0,
these springs will make your car more aggresive
I run the 1.0 springs makes car real snappy
Old 02-25-2007, 11:52 PM   #12
I know usng a stiffer spring will make the clutch engagement snappy, but doesn't the clutch also engage later?
Old 02-26-2007, 01:18 PM   #13
THIS IS WHY YOU NEED A FAST THROTTLE SERVO .06
my truck responds just like electric
Old 02-26-2007, 10:15 PM   #14
Ok, cool.
Old 02-26-2007, 10:29 PM   #15
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I run the competiton (Losi AD2) and have installed an Airtronics 94357z for steering (~$100) and a 94737 (~$70 though now discontinued) and I say it is about perfect. For servos look into Airtronics, Futaba, JR, or KO Propo. Some people have also like the ACE brand, but Ive never seen it. If your racing, do spend more, it WILL make a difference. If you cant afford it, great servos are sold on this board quite frequently. Last, HAVE FUN!
rezenclowd3 is offline   Reply With Quote
hyper7 shock questions and other questions buds302 Nitro Off-Road 1 06-11-2008 12:03 AM
B4: Kit vs RTR, Questions. BelialX13 Rookie Zone 15 02-14-2008 04:57 PM
kanai diff questions and other questions famous182 Electric Off-Road 2 02-25-2006 02:19 PM
TNX QUESTIONS chrometwanks Monster Trucks 2 02-03-2006 06:02 PM
TB questions nekmiyevo2 Electric On-Road 7 08-11-2005 09:37 AM
