Old 02-24-2007, 11:12 PM   #1
Default How do starter boxes work? Do they work with Shaft Start engines?
i have an ofna jammin x1-cr RTR and im wondering how the starter boxes work.
it seems easier than a roto start thing, and it holds the car off the ground to prevent runaways
how do they work?
Ofna_Driver_777 is offline   Reply With Quote
Old 02-24-2007, 11:15 PM   #2
Turbine_au's Avatar
An electric powered motor spins a rubber coated wheel. When you push the car down on the box, it engages this electric motor. The rubber wheel then comes in contact with the flywheel of the engine, spinning the flywheel. This of course, starts the engine.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 02-24-2007, 11:23 PM   #3
and this would work with a jammin 1/8 buggy that is a rotostart?
Old 02-24-2007, 11:29 PM   #4
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
1armed1 is offline   Reply With Quote
Old 02-24-2007, 11:32 PM   #5
worth the money?
Old 02-25-2007, 06:14 AM   #6
Turbine_au's Avatar
Yeah, it would work, look at the underneath of your car. Can you see the flywheel through a hole in the chassis? That's what the hole is for, the starter box. I've never had a rotostart so I wouldn't know how easy it is to use, but honestly, using a starter box makes life easy. The only semi-bad thing you need to do is set the box up which isnt that hard.
Old 02-25-2007, 09:04 AM   #7
you need 6 cell batteries though right?
Old 02-25-2007, 07:51 PM   #8
Turbine_au's Avatar
Depends on the box, you'll either need two stick style batteries or a sing 12V lead-acid battery.
you guys ever design tool boxes or your work areas big_jim1976 Painting, Designs, Graphics and Photography 2 07-20-2008 09:21 AM
will this starter box work ok? ktmusa Nitro Off-Road 4 06-17-2008 06:35 AM
pull start doesnt work with glow plug in atebit Rookie Zone 8 08-27-2007 08:03 PM
How do starter boxes work? karlmaddock Nitro On-Road 5 07-19-2006 06:49 AM
NTC3 Pull Start on an AE starter box ~ Will it work? Ducati-Rider Nitro On-Road 5 01-25-2004 02:06 AM
