Old 02-24-2007, 08:10 AM   #16
Thanks for all the replies guys
Is there any complete tool kit that I can purchase so I can fully dissamble the car?
Is there a tune-up I can do on the car?
I know for my regular car that includes plugs, wires, fuel and air filter, but I'm not sure what the tune up for this little guy is
Thanks!
J30Guy612 is offline   Reply With Quote
Old 02-24-2007, 09:39 AM   #17
xxx-ntad2 racer's Avatar
Trader Rating: 24 (100%+)
next time you go to your LHS ask them about a tool kit for the losi xxx-nt (or a kit that will work with the losi company). next thing i'd do is check for any parts that need replaceing.
btw, i have a few rear suspension arms (the things your shocks hook on to. probably around 4 in. long and an inch wide. connects to the chassis. found in the rear.) and if you want them, PM me your address and i'll ship them to ya for free. 2 are for the left side and 1 is for the right. (if you look from the rear). probably $8.00 worth.
lmk. i'd be happy to give them to ya
alex.
Hobby Pro USA
www.Hobbyprousa.com
xxx-ntad2 racer is offline   Reply With Quote
Old 02-24-2007, 06:42 PM   #18
Thanks very much for the offer!
I sent you a PM, thanks again for being so generous!
Old 02-25-2007, 07:47 AM   #19
no problem.
Hobby Pro USA
www.Hobbyprousa.com
Old 02-25-2007, 08:18 AM   #20
Turbine_au's Avatar
As for the tune-up, being second hand, I'd probably replace the air filter, fuel filter (if it doesn't have one, get one), clutch bearings and maybe clutch shoes, depending on wear. I'd also give it a good clean, and check that the other bearings are in good shape. Also remember to get a good quality air filter oil designed for this kind of application. The right stuff is a really sticky, almost honey like consistency.
Losi sells full hex wrench sets, just need to find out if yours has imperial or metric scews then get the matching set:
http://www.amainhobbies.com/index.ph...a&filter_id=62
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 02-26-2007, 08:14 AM   #21
Thanks for the help!
Old 02-26-2007, 08:21 AM   #22
Is this the air filter I want to order:
http://www.losipartshouse.com/servle...ter-Kit/Detail
I am looking for the fuel filter, clutch bearings, and shoes.
Old 02-26-2007, 04:53 PM   #23
can't really help ya on the air filter selection but i just wanted to tell ya your parts were shipped this afternoon.
thanks.
Hobby Pro USA
www.Hobbyprousa.com
Old 02-26-2007, 06:04 PM   #24
AzBobby's Avatar
Originally Posted by J30Guy612
Also, the right rear wheel looks like it's at a pretty strong angle when compared to the other rear wheel. Should I be worried about this?
Can I reset everything to like a default or something?
I don't have a manual, so that is a real bummer. I bet there is a ton of valuable info in there.
you can download a manual from teamlosi.com
the rears are set up for toe-in for handling purposes. actually when i ran the xxx-nt i opted for more rear toe-in by way of different hubs offered by team losi. an old tooth brush and an air compressor are great for cleaning it up. warm water and soap for the body as it will cake up with oil from the exhaust. some simple green also just before you blow it off and then some wd-40 in the bearing areas and the hinge pins areas are good also.
GO TECH
AzBobby is offline   Reply With Quote
Old 02-26-2007, 09:01 PM   #25
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Nice truck man.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 02-27-2007, 08:59 PM   #26
Thanks!
Old 02-28-2007, 07:31 AM   #27
Hey guys which manual is best to download for my truck it didn't come with one.
I found the older XXX-NT on there, but it's only exploded views of the parts, no operations manual like I have found for the other vehicles.
I want to read up on the suggestions for tuning, suspension, etc.
Should I just download the XXX-NT RTR2 RE or will that be totally different than my truck?
Thanks!
Old 02-28-2007, 11:45 AM   #28
LOWGEARED's Avatar
Get the mach15 manual the original manual or the new one should work for the engine!
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Odd Posts Timing Only Post by People who only post for sale section? mtx33 R/C Items: For Sale/Trade 25 06-20-2008 11:14 AM
dbl post. nm wevie Electric Off-Road 0 02-11-2008 05:43 PM
Sorry for the re-post Buggyboy2007 Nitro Off-Road 11 12-18-2007 10:05 AM
hey my first post _kylex_ R/C Racers 4 Christ 6 10-11-2004 03:29 PM
How About Post Your Car Here? Mugen Power Nitro On-Road 47 08-22-2004 11:03 PM
