Old 02-19-2007, 10:50 PM   #1
trebor's Avatar
Default IS IT LEGAL????
I JUST PUT THE GT2 RPM ARMS ON MY T4 AND I AM BEING TOLD THAT THEY ARE NOT LEGAL. IS THIS TRUE?
trebor is offline   Reply With Quote
Old 02-19-2007, 11:04 PM   #2
TheTurtleMan's Avatar
Trader Rating: 31 (100%+)
As long as it is not wider.
CLICK HERE FOR ALL YOUR RADIO AND MORE SKINZ!!!!
http://www.rctech.net/forum/showthread.php?t=184104
WWW.BUSTOUTBMX.COM
TheTurtleMan is offline   Reply With Quote
Old 02-20-2007, 06:09 AM   #3
AzBobby's Avatar
yes as long as it doesn't change the track width of the rear end your ok. however with the lower end of the shock mounting changing from the t4 arms it is going to affect the rear and geometry alot and it don't see where it is any kind of performance gain at all for you. if anything you have hurt the handling by raising the lower shock mount position. since you have now changed the the triangle of the suspension.
GO TECH
AzBobby is offline   Reply With Quote
Old 02-20-2007, 10:40 AM   #4
The RPM GT2 arms will only fit the front of the T4.
redneckracer197 is offline   Reply With Quote
Old 02-20-2007, 11:13 AM   #5
AzBobby's Avatar
the gt2 and t4 front arms are the same.
GO TECH
Old 02-20-2007, 11:24 AM   #6
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
what exactly is the reason they are saying they are not legal? I am planning on doing this to a T4 when I pick one up for my daugher primarily.
Let me know how well they went on your T4 and what all you needed to do it with if you don't mind.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 02-20-2007, 11:55 AM   #7
trebor's Avatar
thanks all.
cain- i dont really know why they were saying its illegal. i honestly think they wer just jealous because i had emailed rcproseries and a gentleman name lester i think, says they are fine. but yeah, i personally like them and am just getting used to them. and on one of the forums they say you have to use the outer hinge pins for the gt2 with them but i ordered them but they sent the wrong ones so i just used the t4 ones and cut like 3, maybe 4 mm off them. and so far so good. the best thing is i wont have to worry about snapping them so easy now. awesome!! oh, and you have to use the bulkhead that comes with the set. and the spacer on the outer pins are NOT needed anymore. have fun! and rrrrip it up.
Old 02-20-2007, 11:57 AM   #8
SpeedyDad's Avatar
Just curious. Why do you want the GT2 arms to begin with? Is there an advantage to them?
Chris Krieg
X Factory SCX-60 chassis #00 & SCX-60CF prototype #1(both retired)
X Factory X-6, X-60CF (prototype #2), SCX-60CF
X Factory - www.xfactoryrc.com
Stickit1racing - www.stickit1racing.com
SpeedyDad is offline   Reply With Quote
Old 02-20-2007, 11:58 AM   #9
trebor's Avatar
hey cain,
i just bought the sb pro kit from mrc because i couldnt resist the price!! but could you tell me any tips on it? just pm me if possible.
Old 02-20-2007, 12:01 PM   #10
trebor's Avatar
because RPM are known to be heavy duty, top of the line products. im not saying they make the car any faster, hell,probably makes it slower.jk i was just sick of bumping into somebody and snapping them. especially up here in MA where its cold in the track and things break easier. i think the LHS purposely keeps it 40 degrees or colder when they need to make money.lol
Old 02-21-2007, 01:50 AM   #11
AzBobby's Avatar
where you using the FT arms, meaning graphite? in severe cold they could be a bit more brittle, but the stock arms that are plastic only should be good for where you race, the rpm arms are so bendy that i feel they take alot away from the handling. you can get to much flex at some point. but with that much flex they won't break as often.
GO TECH
Old 02-21-2007, 02:51 AM   #12
trebor's Avatar
azbobby- you couldbe right because the handling kinda sucks and ive been adjusting it left and right. and yes i was using the plastic ones. its just i think the LHS keeps it freezing on the track so we do break parts so we have to buy them.lol.
Old 02-21-2007, 05:06 AM   #13
Tech Legend
Cain's Avatar
you could try boiling the plastic arms. I just wish the T4 fronts were more beefy.
Old 02-21-2007, 08:05 AM   #14
trebor's Avatar
hey cain, does boiling them soften them or what? and i agree with you about having beefier arms.
Old 02-21-2007, 12:34 PM   #15
Tech Legend
Cain's Avatar
boiling them (the plastic ones) from what I have told will soften them a bit, so they give alittle more in a crash.
Since the RPM arms are softer, the steering will not be as direct, sort of like when going from plastic to graphite. On a tight track, that could be an issue. But, if you find you can't finish the race, doesn't matter much in the long run.
Drop me a PM with your email address and I will get you the SB V1 FAQ and answer any questions you have.
LEGAL MAH willcunningham Florida Racing 3 12-19-2006 03:56 PM
TCS Legal Car www.ccugolf.com R/C Items: Wanted to Buy 1 11-24-2005 12:36 PM
Good non-Roar legal bodies and non legal wings imjonah Painting, Designs, Graphics and Photography 4 10-30-2004 09:42 PM
Is this legal??? Speed Demon Electric On-Road 6 10-09-2004 09:48 AM
Legal? hogdaddy77 Painting, Designs, Graphics and Photography 10 07-26-2004 06:37 AM
