Old 02-21-2007, 11:32 PM   #31
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Dr. Evil
Hi. I have a XX-4 and a XXX-4 as well. I enjoy both cars. The XX-4 in the pic I am posting has upgraded outdrives and a rear wing mount. This unit was an original XX-4 purcahsed when the car first came out. Since, I have of course gone through at least 1 dozen original shock towers. After they change to the new show shock tower which most people have, I have only broken 1. I have upgraded the shocks, I use to have the trinity blue bulk head which lasted up until last year. This is my 3rd chassis. Overall in the 10 years that I have had the car, I would say the belts are the hardest to deal with due to the time it takes to change it. I will say this much, the car jumps wonderfully. I like it much better than my XXX-4. The XXX-4 has the same upgraded outdrives. I think the XXX-4 is faster on the straights though.
That picture is off ebay - http://cgi.ebay.com/Aftermarket-allo...QQcmdZViewItem
Cheers
Drift_Buggy is offline   Reply With Quote
Old 02-21-2007, 11:35 PM   #32
The Fuhrer's Avatar
Guys,
I'm talking about the outer front hinge pins, not the bulkhead brace (which is modded atm).
I can't see any room to simply drill through the arm/hub carrier and inserting a pin without fouling the universal joint......
www.rcrs.com.au www.knoxrcclub.com
Büszke Knox/Wodonga tag.
Knox Bluegroove. OG since 2014...
The Fuhrer is offline   Reply With Quote
Old 02-22-2007, 08:11 AM   #33
TOEBSTER2's Avatar
Originally Posted by Vegaspilot
Are the XXX-4 arms the same as the XX-4 arms up front? Dimension wise anyway.
Yes arms are different. They are a tad shorter than the XX4 arms but overall you only loose about a 1/4 inch to width of the car. The inside arm has to be shaved just alittle to fit on the XX4 bulkhead. You don't need to do this for the hinge pin mod, but I did cuz the XXX4 arms are way beefier than the stock XX4.
Crookid Creations
TOEBSTER2 is offline   Reply With Quote
Old 02-22-2007, 08:15 AM   #34
TOEBSTER2's Avatar
You can also see where I drilled a small hole in the arm, I put a grub screw in to hold the outter hinge pin so you don't need e-clips. You can see it better on the right side of the pic.
Crookid Creations
Old 02-22-2007, 09:18 AM   #35
rmargiotta's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to rmargiotta
Originally Posted by SupahDave
I havent drove in about 7 1/2 years because i joined the navy and being a junior rank i couldnt afford it. I recently went to Cutting Edge R/C in Las Vegas and ran expert 4wd Mod. Suprisingly i did fairly well, i took the 3rd qualifier and qualified .5 seconds under the TQ in a 7 car class. THe funnest part of the night was laughing at the 3 BJ4 owners because i beat them with an 8 year old car! =)
Im completely stoked about getting back into the sport again.
So now its all about getting my stuff up to date. I need to send my bc112c charger in for a major software upgrade, and been buying battery packs.
Just a thought, its been so long, the best battery i had in my box was a matched 1700mAh NiCad. They still work too, but not race worthy. Now its back to finding out setup that works!
Hope to see you guys around!
Nice results haha. Like I was saying I bought mine just to go to some big'ish' race in OK, where I qualified 3 spots in front of a factory J Concepts/Associated driver, and ended up 2 sec behind a factory losi guy in both of our fastest runs in the triple A's!!!
This car is awesome!
Sponsors:
- Cold Hard-Earned Cash Money -
rmargiotta is offline   Reply With Quote
Old 02-22-2007, 11:09 AM   #36
Trader Rating: 28 (100%+)
What pinion would be recommended running stock spur, and novak gtb with a 6.5 motor?
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 02-22-2007, 05:58 PM   #37
On a short track i ran a 16t/84.....im not sure what the WE spur is....but per the manual, gear it 2-3 teeth lower than recommended equivalent motor. a 6.5 is about a 13 turn, so i would try a 17 for a tight track and 18 for a longer open track and adjust form there based on how it runs. (this is an 84 spur)
Your manual should tell you what to run a 13t mod at and try 2-3 teeth lower.
SupahDave is offline   Reply With Quote
Old 02-22-2007, 07:37 PM   #38
Thanks Dave.
Old 02-23-2007, 02:47 PM   #39
TOEBSTER2's Avatar
Lucky I went through and matched all my shocks today, I found a flaw with XXX4 arms on the XX4. Turns out the left side will not except the XX4 CVD. It hits the Diff screw head not allowing it to travel as far down as the right side. That wouldn't be good cuz it could jam the front diff when landing or break a belt. So now I will have to find some cvd's that are a tad shorter for that setup to work.
Crookid Creations
Old 02-23-2007, 07:51 PM   #40
frankiecmgt's Avatar
Trader Rating: 77 (100%+)
HI GUYS.
I JUST PUT MY BRUSHLESS XX4 WITH LI-PO'S UP FOR SALE. TAKE A LOOK....
I AM A BELIEVER IN THE R/C TECH UN-WRITTEN RULE " HE WHO HAS THE LOWER FEEDBACK SHIP'S FIRST "......
frankiecmgt is offline   Reply With Quote
Old 02-24-2007, 10:31 AM   #41
Dr. Evil's Avatar
Default Losi xxx-4 /xx-4 cars
Hi guys. I spoke to an individual at Team Losi about anything new coming out in place of the XXX-4. He stated there wasn't anything new coming out and no plans for anything at least this year. Just to strike up a conversation, do you guys feel the 4wd market has fallen due to the truggies/ 1/8 scale buggies?? I notice last year, many people with 4wd 10th scalers were getting into 1/8 scale. This seemed to be because of the Lipo and Novak Esc explosions that I was hearing about from many of my friends that own the Novak Product. Many people were frying their ESC I think because they were not meant to handle such a high current imput.
Also, what would you guys like to see as hopups for the XX-4 and the XXX-4??
Dr. Evil is offline   Reply With Quote
Old 02-25-2007, 11:55 AM   #42
Dougg's Avatar
Is there a upgrade from the graphite front A-arms to something different that is stronger. I've done the hinge pin upgrade. I'm breaking them in other places. Delron or aluminum? anybody make?
thanks
Doug
MBX7r, MBX7R Eco, 22-4 2.0
Dougg is offline   Reply With Quote
Old 02-25-2007, 01:47 PM   #43
Trader Rating: 96 (100%+)
You can go with the plastic front arms. I'm not too sure about the Delrin arms, I guess it wouldn't hurt to try them.
A modification that won't cost anything.........don't hit anything.
K.Copeland is offline   Reply With Quote
Old 02-26-2007, 09:42 PM   #44
Send a message via AIM to Brushless Corey
What would be a good pinion gear to run with my 5.5? I have a few extra pinions from years ago and while re-installing my motor and ESC the other night I went ahead and put a 22 tooth on it for now. As far as the spur gear I think its the stock one.
Brushless Corey is offline   Reply With Quote
Old 02-26-2007, 09:59 PM   #45
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Well I'm running the 6.5 brushless in my XX4. I have an 18 pinion on it.
You could probably run the same or even a 17 pinion.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
HELP NON RACERS HELP MORE THAN RACERS SO WAKE UP ALL YOU OFF ROAD RACERS IN MELB/VIC richard 1000 Australian Racing 15 06-20-2006 11:35 PM
Need Racers!!! jackington Electric On-Road 32 04-09-2005 03:18 PM
Why won't electric racers travel as much as gas racers? TSB Northwest Racers 28 05-15-2004 08:06 PM
By The Racers For The Racers July 12 Hobbytown Glen Burnie pusher R/C Items: For Sale/Trade 9 07-09-2003 08:13 PM
By The Racers For The Racers..July 12 Hobbytown Glen Burnie pusher Racing Forum 2 07-07-2003 02:08 PM
