Old 02-18-2007, 06:36 PM   #1
easy e's Avatar
Trader Rating: 28 (100%+)
Default LiPO for XX-4 ??
I want to run LiPO in my XX-4 but im not sure what battery to run to obtain the saddle pack format. thanks -
also i think i would like to get a lipo with a high mah rating even i have to spend alittle more so i can just have one battery to keep recharging during the race day
easy e is offline   Reply With Quote
Old 02-18-2007, 07:22 PM   #2
T. Thomas's Avatar
http://maxamps.com/index.html?lmd=38519.529109
Currently, these are the only guys making saddle lipo packs that I am know of. Click the Lipo Car Packs link on the left side and it will bring them up, just scroll down a little.
T. Thomas is offline   Reply With Quote
Old 02-18-2007, 09:00 PM   #3
Trader Rating: 14 (100%+)
there is a guy here locally that ran lipos in his xx-4 for 2 heats. For the 3rd heat and every other time he's run the car has had nothing but 4200's in it.
o.s. power is offline   Reply With Quote
Old 02-18-2007, 11:15 PM   #4
glassdoctor's Avatar
I run lipos in my XX4... I have one pack of the cells that maxamps uses currently and one with an older style cell. The old ones actually are a much better size.. but you can't get them anymore. The new ones are kinda small, lenfth and width.. so that makes the packs taller. But they are better, more powerful cells though.
I have a 4400mah pack... and it doesn't really fit using the stock battery holdowns. I just made some out of lexan. My older packs are actually too short and need some foam spacer under the holdowns.
I added weight to the rear bumper of the car to make minimum spec and help settle the rear. 1-2oz... can't remeber exactly... will depend on your other elctronics.
Threre aren't too many good cells that are a good size... about 40-45mm wide x 65-70mm long.
glassdoctor is offline   Reply With Quote
Old 02-19-2007, 08:59 PM   #5
Trader Rating: 54 (100%+)
I use the maxamps 4400 saddle packs and they work great. I took the stock battery straps and dremeled them smooth top and bottom then dremeled the cover plate lips smooth.
I just plug it into the charger between rounds to top it off. Works great. I tried the 5500's at first, but could not get them strapped solid enough without sticking them in with double-sided tape.
jsmax is offline   Reply With Quote
Old 02-19-2007, 09:18 PM   #6
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Are they legal for racing. My local track doesn't allow them.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 02-19-2007, 09:23 PM   #7
chris c's Avatar
Trader Rating: 60 (100%+)
I thought slim said anything goes in mod......
Might want to check with him matt
Wayne runs some and i know a few others do.
chris c is offline   Reply With Quote
Old 02-19-2007, 09:59 PM   #8
It's mod 4wd... who cares if it has lipos. My local tracks dont' really care. It's not like a brushless system isn't fast enough without the lipos.
Explain that it's just a personal choice to run a single lipo rather than having to cut up several of your racing packs to make saddles... it's not about trying to get an advantage on the track.
Old 02-20-2007, 04:03 AM   #9
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
I have seen a normal lipo stick pack in a xx4. Ill try to find the pic
Cheers
Drift_Buggy is offline   Reply With Quote
Old 02-20-2007, 04:09 AM   #10
Found it
Cheers
NIP Novak 5amp lipo regulator with volt monitor, NIP venom 1600mah lipo rx pack sharkman R/C Items: For Sale/Trade 1 06-10-2008 02:36 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
FS TrakPower 7.4V 4900MAH Hardshell Lipo,TrakPowerBalancer,TrinityReference 4500 Lipo ffpm46 R/C Items: For Sale/Trade 11 01-29-2008 06:11 PM
Pg 2 on Complete Sellout Motor rebuild Orion Lipo, peak Lipo 4800 and more gunlocators R/C Items: For Sale/Trade 18 10-08-2007 02:11 PM
Lipo charger with power supply and 2 cell lipo pack fweemindan R/C Items: For Sale/Trade 3 01-03-2007 11:51 PM
