Old 02-17-2007, 08:29 PM   #1
chris c's Avatar
Trader Rating: 60 (100%+)
Default GTB problems???
I have a gtb with a 13.5 in my MF2 and with only IB batteries I have a very bad stumbling problem from stop to full throttle. It is only with IB batteries. I have 3 IB's 2 38 and 1 42. With GP 3300 and 4300 it does not do it
I have re sync the esc to no avail.
WEIRD huh anyone else wit the same prob? Only thing I can think is ib might have a faster inital voltage drop causing it......
HELP!
chris c is offline   Reply With Quote
Old 02-17-2007, 11:22 PM   #2
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Hey Chris I know you have been having problems. Your qualifier on Fri night was not good, but something with your IB's. That was weird.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 02-18-2007, 12:32 AM   #3
Trader Rating: 28 (100%+)
My IB 3800's work just as well as my gp 3300's with my gtb/6.5
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 02-18-2007, 01:09 AM   #4
jgroenhof's Avatar
Default Whats up Chris!
Is this the first case I've heard of where the tape along the sides of the battery box might make a difference?
Graphite is conductive. Losi sells the tape. No one uses it. IB's are a bit longer than GP's. They work fine in my truck. This does not add up.
Weird is the word.
Have you tried the 13.5/IB cell combo in your XXX-CR?
Johnny G
OCRC.
jgroenhof is offline   Reply With Quote
Old 02-18-2007, 03:17 AM   #5
AzBobby's Avatar
yes there is a tape that comes with losi and team AE. i haven't used it for about 4 years now and i have the same batts as you.
are you running your esc wire under your batteries to the reciever? if you are, that is your problem. i had the same thing happen to me, and once Charlie from novak showed me why, i had no clue. i now run the 9" wire from my esc to my reciever, going up to the steering servo then to the reciever. going under that betteries caused major issues over time.
what happens is that the wire ends up under one or more of the cells and when you land from any jump. i glitched. sometimes 2-3 secs. and sometimes so much that i had to pull off the track. what happens is when you land the wire is being pinched by the battery cell and causing a short in power to the esc or the reciever or both. this is more likely your problem. people are always quick to blame graphite when it is something else. but yes graphite conducts better than pure plastic but now to the extent that you are having problems.
GO TECH
AzBobby is offline   Reply With Quote
Old 02-18-2007, 11:44 AM   #6
chris c's Avatar
found the problem....
According to steve at Novak.....
The early 13.5 motors need another shim installed. He said they know of the problem with the motor and IB's. He said its with the 13.5 only and its a easy fix. So off to novak i go tomorrow
Thanks guys
Old 02-18-2007, 11:45 AM   #7
chris c's Avatar
Weird is the word.
John,,,
I have the tape on my cars.... and nope have not run it in the cr yet.
I had no problems with the ib's and a brushed set-up...
Chris
Old 02-18-2007, 11:46 AM   #8
AzBobby's Avatar
Thanks guys
hmm.....
GO TECH
Old 02-20-2007, 08:30 PM   #9
chris c's Avatar
Just had the GREAT guys at Novak look at my 13.5,install a sintered rotor and shin the can.
PROBLEM FIXED!!!!!!!
FYI guys the old ones need shims.
b4/t4 problems trdsupra88 Electric Off-Road 12 03-15-2008 10:52 PM
JR Z-1 Problems...need help! pumpkinfish Radio and Electronics 3 10-24-2007 05:31 PM
Problems.. Oasis Chat Lounge 9 01-16-2006 08:41 AM
tc3 one way problems dontfeelcold Australian Racing 7 12-31-2003 04:34 PM
Set Up Problems Griz Australian Racing 5 12-05-2003 12:44 AM
