Old 02-17-2007, 01:20 PM   #1
GReddy's Avatar
Send a message via AIM to GReddy
Default please help - stuck carb
anyone experience this? the carb seems to be stuck when throttle is applied and then i have to manually shut the carb to idle agian
GReddy is offline   Reply With Quote
Old 02-17-2007, 01:46 PM   #2
GReddy,
Not much info to go on but check the following:
1. Throttle linkage binding
2. Idle speed screw dragging on throttle slide (carb adjustment).
3. Stripped servo gears.
4. Transmitter trims.
Larry
LClarke is offline   Reply With Quote
Old 02-17-2007, 02:21 PM   #3
GReddy's Avatar
i know that it was even like that when it was new, so cant be the servo or trims
ive noticed that if you screw the idle screw in a lot more then needed then it wont be stuck and will slide smoothly
Old 02-17-2007, 02:44 PM   #4
GReddy,
Turn your idle screw counter-clockwise until the slide is completly closed then turn it clockwise until the slide opening is .3-.5mm. this a very small opening about a 16th of an inch. Let me know if this frees up the throttle binding because if it does we have some engine tuning to take care of.
Larry
Old 02-17-2007, 03:30 PM   #5
AzBobby's Avatar
is it a rotary carb? if it is, it can possibly be that the idle screw is no longer in the groove on the slide and would cause it to hang up also. not as common on a slide carb but can happen there too. past that do you have return spring on throttle, also it could be that linkage was installed binded up from the beginning if it is a rtr.
GO TECH
AzBobby is offline   Reply With Quote
Old 02-17-2007, 05:02 PM   #6
GReddy's Avatar
its a slide, i use those clear hair bands as return springs
the linkage you know how when you throttle it theres a collar to hold the sleave allowing the linkage to be pulled
but when breaking/returning to neutral theres a spring on that side so i guess that could cause the servo to push the spring instead of the carb valve, but even then the carb shouldnt be getting stuck right?
Old 02-17-2007, 05:39 PM   #7
Remove the linkage from the carb slide, move the slide in and out, it should be very easy almost silky smooth. The rubber bands should not be used as a return spring, they are only there to act as a fail safe. The spring on your throttle linkage is what returns the slide to the closed or any intermediate position. The collar that holds the spring against the servo horn should be adjusted so there is a slight pressure to alleviate any slop in the link. The idea is to allow the servo to reverse during the use of brakes without limiting the brake travel.
Old 02-17-2007, 05:59 PM   #8
GReddy's Avatar
yeah but its not smooth at all
Old 02-17-2007, 06:12 PM   #9
Is the idle stop screw backed out? If it is and the slide is still binding remove the idle stop screw completely, loosen the dust boot from the carb and pull out the slide. Check for signs of the idle stop screw gouging the slide in the alignment track and any other areas that may cause binding. The slide must move freely and smoothly.
Old 02-19-2007, 04:27 PM   #10
GReddy's Avatar
i tried it agian today and it seems to run great but when it reaches near max temp. the valve starts acting up and gets stuck
shutting the engine and testing the carb as it cools as long as i let go of throttle right away it doesnt stick but if i let go slowly it sticks and u can hear it "pop" back to close
Old 02-19-2007, 05:03 PM   #11
AzBobby's Avatar
very weird. i would definetely disassemble the carb still and look at everything. also i wonder if maybe your servo is crapping out, or a stripped gear in it.
GO TECH
Old 02-19-2007, 05:14 PM   #12
GReddy's Avatar
its not the servo because i disconnected the linkage and moved it by hand
Old 02-19-2007, 09:30 PM   #13
amain's Avatar
do you have any engines around that the same size? ie .12-.18 /.21 .30? If so take another carb and throw it on the engine. engiens dont mind having diffrent carbs . infact some engines run better with diffrent carbs
amain is offline   Reply With Quote
Old 02-19-2007, 09:47 PM   #14
GReddy's Avatar
i have another its the carb from the rtr engine from kyosho but that carb is eh..
Old 02-20-2007, 09:42 PM   #15
LOWGEARED's Avatar
maybe it just needs to be cleaned..... I noticed build up on mine today !!!! that hinders performance !!!
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Help! Stuck Carb! hrnts69 Nitro Off-Road 10 12-09-2008 08:10 AM
Converting Rotary Carb to Slide Carb? hrnts69 Nitro Off-Road 1 07-18-2008 12:29 PM
WTB 11L ROTARY CARB FOR .18TZ, HAVE NEW SLIDE CARB TO TRADE? SHAGGS R/C Items: Wanted to Buy 0 12-01-2006 03:34 PM
Sirio .12 with Novarossie Carb -CX12 carb fit? au_Nightmare Onroad Nitro Engine Zone 10 09-25-2004 09:29 AM
Sirio .12 with Novarossie Carb -CX12 carb fit? au_Nightmare Nitro On-Road 5 12-15-2003 03:24 PM
