Old 02-17-2007, 01:08 PM   #1
Default Ongoing thread of Newbie Questions about a Jammin X1 CR RTR....
I've decided to make a thread so then i dont need to make a new topic for every question i have about my new RC.
So here it is.
Ofna_Driver_777 is offline   Reply With Quote
Old 02-17-2007, 01:09 PM   #2
1st Question
How hot should my car be running?
I've taken the temp after running it for a tank or two and its at 234. (thats the highest it got)
is that to hot? what should i do?
Old 02-17-2007, 02:17 PM   #3
Ofna_driver_777,
Your temp is in the ball park, ensure you maintain a light trail of smoke during full throttle applications. Always adjust the high speed needle first. Make numerous full throtttle runs, always maintain the light trail of smoke as you lean the high speed needle for the highest speed. After your satisfied with the high speed setting bring the car to stop and allow the engine to idle for about 5 seconds then give it full throttle, it should accelerate smoothly and rapidly. If it does not and puffs out a thick stream of smoke the low speed needle is to rich turn the needle 45-90 degrees clockwise and repeat procedure. If it speeds up rapidly and then bogs down the low speed neddle is to lean turn it 45-90 degrees counter-clockwise and repeat. After your high and low speed settings are good you can adjust the idle screw for a reliable idle. Remember 2 stroke glow engines will begin to "load up" (excessive fuel) if their allowed to idle for an extended period of time. This is normal. Thats all there is to it.
Larry
LClarke is offline   Reply With Quote
Old 02-17-2007, 03:12 PM   #4
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
234 seems about right. Most engines run between 210 - 250
Cheers
Drift_Buggy is offline   Reply With Quote
Old 02-17-2007, 03:12 PM   #5
LOWGEARED's Avatar
So here it is.
Oh ya sure we've heard that one before!!! LOL
You just wanted to post another thread with your name on it!!! J/K
Diggin your JAMMIN man?
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 02-17-2007, 03:29 PM   #6
yeah it is so awesome
Old 02-17-2007, 04:17 PM   #7
About time, sheesh...
gatermaxx is offline   Reply With Quote
Old 02-17-2007, 06:40 PM   #8
HEY.
you have to learn sometime right
Old 02-17-2007, 09:20 PM   #9
Question 2
The failsafe is turning on when its maybe 150ish feet away...
I've charged the battery in the car, and checked the batteries in the remote (with one of those AA tester strips)....
Whats goin on? How often should i be charging the car battery?
Old 02-17-2007, 09:36 PM   #10
losi guy's Avatar
Trader Rating: 38 (100%+)
Send a message via ICQ to losi guy
Just from my experience on the 2 or 3 ofna rtr's i bought i had nothing but problems with the failsafe's, they never seemed to work the way they were supposed to so i used a different brand and didn't have any problems. plus i know when i first got my rtr's i had set them up and i did over and over but i had no luck.
Spektrum | Avid | DE Racing | Tekno
losi guy is offline   Reply With Quote
Old 02-18-2007, 11:20 AM   #11
hm, but it seems im loosing raidio connection when it goes that far away. donno if its the failsafe thats the problem
Old 02-18-2007, 01:49 PM   #12
annie_himself's Avatar
Send a message via AIM to annie_himself
Take out the fail safe to see if it stops. I've never needed a fail safe except for that one runaway that caused no damages.
annie_himself is offline   Reply With Quote
Old 02-18-2007, 07:54 PM   #13
yeah, but if it doesn't stop and i get to far away it'll keep going and i'll be FUBAR
Old 02-18-2007, 08:01 PM   #14
Question 3
I have street tires and im doing spins and sliding and burning out going at full speed. Will this ruin my tires and is it in any way bad for the car?
I go full throttle for a stretch and then take off the gas and pull a 180, and then full throttle it going the other way... is that bad?
Old 02-18-2007, 08:18 PM   #15
Paradoxmaker's Avatar
Question 3
Well spinning the tires excessively will wear them out quicker than normal use.
Is pulling full throttle 180's bad? Again is it bad? It can be..... going full throttle and doing a 180 then blasting full throttle again can put the gears under tremendous strain. If something is off or not shimmed well it's going to fail eventually.
Paradoxmaker is offline   Reply With Quote
A few newbie questions bigpete1984 Rookie Zone 9 04-16-2006 02:54 AM
NEWBIE questions jasonctx Malaysian R/C Racers 47 10-20-2005 05:47 AM
Old newbie got some questions. wohcnil Singapore R/C Racers 2 08-02-2005 01:34 AM
Newbie questions. Snikkari Electric Off-Road 3 10-21-2004 05:06 PM
Newbie questions... MaStErOfPuPpEtZ Nitro On-Road 103 11-12-2002 10:24 PM
