Old 02-17-2007, 09:21 AM   #1
Trader Rating: 47 (100%+)
SEALENT QUESTION
What kind of sealent do you guys use to seal up your engine backplates and/or carbs? Any automotive sealent...or is there a true RC sealent that has to be used?
Horizon Hobby/Losi
Sanwa
Savox
HobbyWing
Hyperion
SUNA is offline   Reply With Quote
Old 02-17-2007, 11:13 AM   #2
gubbs3's Avatar
Basically something you can find in any auto parts store. RTV slicone sealant, but make sure it is labeled "sensor safe."
I've had my tube of sealant for years. Someone else could probably elaborate more about the "sensor safe" rating.
gubbs3 is offline   Reply With Quote
Old 02-17-2007, 12:11 PM   #3
AzBobby's Avatar
i use the rtv high temp copper sealant on my motors. also make sure it is rated against fuels and oils, it will say on the back.
GO TECH
AzBobby is offline   Reply With Quote
Old 02-17-2007, 03:33 PM   #4
Nitroaddicts's Avatar
copper RTV
www.NITROADDICTS.com
Get Free T-Shirts with Nitro Points!
Need Track TShirts?
http://www.facebook.com/AmericanGFX
Nitroaddicts is offline   Reply With Quote
Old 02-17-2007, 04:05 PM   #5
mremtr's Avatar
The best stuff you can use for sealing your engines is anaerobic sealer. I have been using the stuff for decades . Doesn't have any effects on engine components and is easy to clean up and never really hardens so removing your carb is not such a chore . You can get it at any good hardware store or auto parts store. Lock-Tite makes it as well as a number of other people.
I really like the stuff that you can get at any GM dealer ,and it comes in a really nice small tube. They have 2 different kinds too ,one for larger gaps called gasketmaker and the other is just a sealer. Both are AWSOME and you only need just a tiny tiny bit to do the job .
Way better than silicone sealers and holds up to the heat better too.
mremtr is offline   Reply With Quote
Old 02-17-2007, 11:55 PM   #6
Horizon Hobby/Losi
Sanwa
Savox
HobbyWing
Hyperion
Old 02-19-2007, 12:17 AM   #7
TKO has one. If Peter's got it then it is good.
http://tkocompetitiondev.com/shop/pr...roducts_id=307
Kyosho Evolva M3 / Kyosho Lazer ZX-5 SP / Xray T3
aantonis is offline   Reply With Quote
Old 02-19-2007, 04:27 AM   #8
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Decent silicone will take 1000+ degrees with no problem, so I doubt that any temperature you're gonna see with an RC motor is going to be an issue.
Turbo Joe is offline   Reply With Quote
Old 02-19-2007, 05:44 AM   #9
mremtr's Avatar
Only problem with the high temp silicone is it adds dimmension to your tolorences ! and can add up to .004 of an inch , not really that good for the back cover , this is why I recommend using the anaerobic sealer, it doesn't add much if any dim. and seals and cures instantly ! it may seem wet on the outside, which is great ,you can simply wipe off the extra ,as it cures with the absence of air ,hence the "anaerobic" in it's name.
Silicone works perfect as well , but doesn't look as professional
Old 02-19-2007, 10:32 AM   #10
Turbo Joe's Avatar
There are people that would have a "professional" result with either...LOL...and some that wouldn't.
Old 02-19-2007, 11:07 AM   #11
mremtr's Avatar
LOL Isn't that the truth
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 09:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 06:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 10:33 AM
