Old 02-17-2007, 12:24 PM   #16
AzBobby's Avatar
[QUOTE=xxx-ntad2 racer]don't mean to be bothersome, but this website says theres around 12 freq. choices.
sorry should have been more clear. on that list the single color freq. are the ones that have been allowed by the fcc for use in the usa. the other six are used in other countires, but there have been some pros bringing those freq. back home with them.
steven the issue you describe is far more serious than motor capicitors. i still think some one with higher quality radio is on your freq. also since they are rtrs and you haven't moved any of the electronics around, that you don't have to worry about the batter wires being right next to the antenna wire or that the antenna is anywhere near your motor. those two things would give you fits as well. from there i would try another set of crystals, your may have been damaged in shipping, or the reciever itself was damaged. after doing all these checks, may still need to call your 1-800 numbers for each car and speak with them. also go through your trouble shooting section in your manuals, and also make sure you did install the antenna as it was decribed. on a rtr it is vital that the antenna is mounted properly.
GO TECH
AzBobby is offline   Reply With Quote
Old 02-17-2007, 01:08 PM   #17
xxx-ntad2 racer's Avatar
Trader Rating: 24 (100%+)
(quote)sorry should have been more clear. on that list the single color freq. are the ones that have been allowed by the fcc for use in the usa. the other six are used in other countires, but there have been some pros bringing those freq. back home with them.(end quote)
i didn't know that about the others being used in other countries. thanks for the info.
Hobby Pro USA
www.Hobbyprousa.com
xxx-ntad2 racer is offline   Reply With Quote
Old 02-17-2007, 03:15 PM   #18
steven19,
Sounds like a frequency conflict, does your cars operate ok at home or away from the track? Losing control outside 10 ft is a sure sign that someone else is operating on your frequency.
Larry
LClarke is offline   Reply With Quote
Old 02-17-2007, 03:22 PM   #19
AzBobby's Avatar
yep no biggy. there are some very odd freq. used in japan and the surrounding areas. if you look at the entry list for the cactus classic you will see these and some others from the europe area as well.
GO TECH
Old 02-17-2007, 05:26 PM   #20
Send a message via AIM to steven19
Default ...
and this is why im a newbie i took it home and ran it around and still had the same problem of only getting about 10 ft. range after frustration sat in i grabbed the plastic antenna holder and my hand slipped well low and behold the antenna wire was cut i just didnt look at it close enough so im hopeing when i replace that ill be back up and going thanks for all the help you guys
steven19 is offline   Reply With Quote
Old 02-17-2007, 05:30 PM   #21
glassdoctor's Avatar
that would do it.
glassdoctor is offline   Reply With Quote
