Old 05-16-2003, 05:26 AM   #46
sosidge's Avatar
nikos - the mid motor MX-4 is also a YMP project www.teamyokomo.com/ymp
I think you would struggle to get one.
Old 05-16-2003, 01:17 PM   #47
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
sosidge - thanks for the information. It's good to find the information about the cars from someone who has worked with them.
In your opinion - which is a better racer. The BC or the MX-4. I am a long time Yokomo driver who wants to try something different. I will have an MX-4 running in a couple of weeks, but just curious to know which car you thought was better, since it sounds like you have used both.
nikos2002 is offline   Reply With Quote
Old 05-16-2003, 03:17 PM   #48
sosidge's Avatar
I've not used the MX-4, just the BC. In the UK the MX-4 became unpopular pretty quickly, I think partly because of it's weight, and partly because of a lack of tunability, they didn't really work on our grippy tracks.
I'm sure there's scope now for an MX-4 to be competitve, virtually all the newest parts from the BC Special will fit on it (caster blocks, toe-in), and it's got a naturally longer wheelbase, plus a slipper clutch. Masami still uses MX-4 based cars as well (though the other Yokomo drivers run BC's).
Old 05-16-2003, 09:30 PM   #49
A tip for MX4 owners...
The main drive gear on the MX4 is made of aluminium and will wear out eventually, when it wears the teeth become sharp and will destroy the rear belt very quickly. So make sure you keep a close eye on it and replace when necesscary.
If you want some carbon fibre parts for it try www.fibre-lyte.co.uk and definately try the yokomo rear 2 deg toe in hubs for the MR4, they use 6x12 bearings but will make a noticeable improvement to the handling.
goodez is offline   Reply With Quote
Old 05-16-2003, 10:23 PM   #50
foampervert's Avatar
Send a message via MSN to foampervert
Default is anyone selling their MX4s?
Salutations Earthlings!
if anyone is selling their MX4s,please do let me know,
the car should be in good running condition, and the chassis should not be too battered.new belts and an un-painted bodyshell/undertray will be good too. i'm sure if there are other parts that req working on, i can get parts locally.
please do let me know!
thanks for looking in!
-FP
i can be contacted via PM or my email: [email protected]
i live in singapore,so any price quotes shld include shipping here.
i will pay via paypal or money order/bank cheque.
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 05-17-2003, 05:50 AM   #51
sosidge's Avatar
Those 2 degree blocks are also available for the 10x6 bearings.
Old 05-17-2003, 05:58 PM   #52
klowne's Avatar
i see this is a thread for yz10...stuff......
im looking for old yz10 rims.......
fronts and rears...... any color....and yes the 4 hub style......
if anyone has any drop me a message or email me ....please......
klowne is offline   Reply With Quote
Old 05-18-2003, 11:12 AM   #53
sosidge's Avatar
If you get REALLY stuck, I know a place that has some old Yoke rims on the shelf - of course, I'm across the Atlantic ocean...
Old 05-18-2003, 03:54 PM   #54
klowne's Avatar
could ya let me know on price ....by chance...... im actually looking for at least 3 to 4 complete sets to be honest.....or whatever i can get ahold of...... i called yokomousa and was told they dont have em.....and then a friend called and the guy he talked to went and did some digging and found some.....go figure i get the guy that doesnt go the extra distance instead pawns me off to call a hobby shop .....
the color doesnt matter either on em.....just as long as they are the 4 hub design
Old 05-18-2003, 10:15 PM   #55
Send a message via MSN to clintscreations Send a message via Yahoo to clintscreations
if there is anyone looking for custom painted MX-4 bodies i just painted 3........they are all different, but only 2 of them have the belly pans!
you can email me at
[email protected]
for more info
thanks
clintscreations is offline   Reply With Quote
Old 05-19-2003, 03:27 AM   #56
sosidge's Avatar
I'll have a look at what he's got next time I'm passing.
Old 05-19-2003, 05:13 AM   #57
klowne's Avatar
thanks sosidge....... let me know...... maybe we can work something out ....... or if you know of anyone that has some laying around they aint using...... they fit nicely on a dominator oval car hehe ...
Old 05-22-2003, 03:59 PM   #58
nikos2002's Avatar
Anyone got any MX4 advice. What is a must have? Anything special to watch out for -- other than the boards!
Old 05-22-2003, 04:28 PM   #59
watch out for...
wear on the main drive gear, see my post above
put a little loctite on the screws that thread into the wing mounts
make sure the slipper is tight and only slips under high loads
dirt and stones collecting in the rear gearbox
if you run on dirt the standard bearings will become contaminated very easily especially the rear outdrive bearings, I've found dynamite red seal bearings to be much better
must haves...
its heavy so any lighter parts are good such as the carbon shock towers and one piece carbon top plate
you can use the plastic outdrives from the other MR4 cars providing you buy the locking diff rings and the different thrust washers and screw (youll have to cut down the right rear outdrive to clear the spur though and you'll need the mr4 front bulkhead assembly too)
2 deg rear hubs
Old 05-27-2003, 04:04 PM   #60
THeGame's Avatar
Send a message via AIM to THeGame
Can someone post a link to the Yokomo 2wd and 4wd cars i cant find them anywhere on the net..?
THeGame is offline   Reply With Quote
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
New forum for yokomo owners lock n load Electric On-Road 0 10-07-2005 07:54 AM
1/8 off-road forum jtkc2001 R/C Tech Site Forum 0 04-16-2005 07:18 PM
Yokomo Worlds Replica Sd Forum DENNIS STORTI Electric On-Road 16 01-02-2005 01:44 PM
Yokomo forum zachariah Malaysian R/C Racers 26 10-08-2003 06:23 AM
