Old 02-13-2007, 09:55 PM   #1
jbmccoy205's Avatar
Trader Rating: 47 (100%+)
Default need new clutch?
I have a Losi xxx RTR 1/10 Nitro....My question is I ran Approx. 2 tanks of gas through it and now it will rev but not move....I checked the diff and it seems to be tight, but I rev the engine and the gears dont move just revs....Need new clutch? please help....thanks
jbmccoy205 is offline   Reply With Quote
Old 02-13-2007, 10:05 PM   #2
40%
40%'s Avatar
Did u try and remove the clutchbell to check if maybe the springs are broken?
40% is offline   Reply With Quote
Old 02-13-2007, 10:08 PM   #3
jbmccoy205's Avatar
springs are not broke just took it apart
Old 02-13-2007, 10:13 PM   #4
AzBobby's Avatar
check your slipper adjustment also. also if you didn't follow the instructions on setting the diff. after the very first run or you overtightened it you may have melted the diff gear itself. you will need to take the tranny out and look at it. means fully disassemble the diff. it will be obvious if it is melted at that point. since your in there i strongly recommend you go with the aluminum diff gear.
GO TECH
AzBobby is offline   Reply With Quote
Old 02-13-2007, 10:19 PM   #5
40%
40%'s Avatar
As above.
Shim between inner clutch bell and clutch shoes razor_clawzz Nitro Off-Road 8 02-03-2008 10:24 PM
New kyosho flywheel and clutch bell plus 2 unopend clutch shooes tlxxx4driver R/C Items: For Sale/Trade 0 07-17-2007 03:54 AM
yamaha gt 80 dirt 4 speed clutch clutch bike 4 speed clutch cheap savage123 Other Items: For Sale/Trade or Wanted to Buy 8 08-10-2006 01:34 PM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 09:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 05:01 PM
