Old 02-11-2007, 08:02 PM   #1
wb-racer-ace's Avatar
Trader Rating: 28 (100%+)
Send a message via Yahoo to wb-racer-ace
Default OS .21 VG
anyone have any opinions on this motor for 1/8th scale off road. what tuning tips may you have. just picked one up. I have a JP1 pipe and a firoini clutch for it.
wb-racer-ace is offline   Reply With Quote
Old 02-11-2007, 09:28 PM   #2
speed metal's Avatar
The VG/RG is a stalwart in the 1/8 scale offroad world. Lots of bottom and mid with a decent top. Easy to tune and holds a tune well. This engine has many fans. I know people that run them excusively in both buggy and truggy. I'm sure you'll like it!
regards
speed metal
speed metal is offline   Reply With Quote
Old 02-11-2007, 09:40 PM   #3
mach51's Avatar
Trader Rating: 30 (100%+)
if i didnt have a stable of vspecs id get the VG
mach51 is offline   Reply With Quote
Old 02-11-2007, 10:20 PM   #4
maxxman101's Avatar
Send a message via MSN to maxxman101
i just picked one up but gonna wait to break it in until it warms up a little. i have been told to add a shim if you are gonna run 30% fuel through it though.
My stable:
Revo 3.3, Kyosho 777 SP2, Kyosho ZX5, Robitronics Scalpel, AE RC18T, TLT1.
Futaba 3PKS with Spektrum
maxxman101 is offline   Reply With Quote
Old 02-11-2007, 10:38 PM   #5
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
Mine only lasted me about 1.5 gallons including breakin but that is probably not typical.
infanterene is offline   Reply With Quote
Old 02-11-2007, 10:45 PM   #6
Good motor but everyone of them Ive seen has had the carb leak. Easy fix with some gasket sealer. There is only one o-ring at the base of the carb. Mine was acting up and sucking air. Sealed it up and it was fixed.
MBX6
X2
O.S. SPEEDs
Hitecs
M11
DSM
and a Retired 8ight.
MonkeyWrench is offline   Reply With Quote
Old 02-12-2007, 07:00 AM   #7
I loved mine for the first gallon, low compression, whould'nt hold tune,
another fellow racer loves his, on his 3rd gallon with no problems, maybe I got
a bad one. replaced with Hot Mod Rex R21BF big difference
sbales is offline   Reply With Quote
Old 02-12-2007, 09:39 AM   #8
Steve Walters's Avatar
Great motor for smaller tracks or club races. I'm running one with a JP-3 pipe, and my V-Spec on Bigger full layout tracks. But, like MonkeyWrench said, take the carb off and Air-Seal it, or with some Higher temp gasket sealer right of the bat. It may not have a carb air leak, but to save yourself a lot of headache (If it does) just spend 5 minutes and seal it. Trust me... There are 3-4 VG at our track and all have had small air leak(s) around the carb at one point or another. Once mine got sealed up tight, the motor came alive! A ton of Low-Med punch with a good top end. (Empty tanks temps 220-230)
Racer Choice Air-seal is great product to have anyways. But its hard to find at time.
http://www.carolinasrc.com/Webstore/...?idproduct=420
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 02-13-2007, 04:39 PM   #9
thanks for the imput!! the only thing on it I'm going to change right away is the cooling head, needs to be larger with a few more fins. I'm going to make a new one this week.
Old 02-14-2007, 04:06 PM   #10
got the monster head started!! should be done friday
Old 02-14-2007, 04:38 PM   #11
vr6
Trader Rating: 22 (100%+)
(wb-racer-ace) what kind of machine are using there? are you doing any live tooling work also?
Ko Propo. Hobbywing. Jconcepts. SMC cells
Also my local track Race em r/c. Rockford Illinois
vr6 is offline   Reply With Quote
Old 02-14-2007, 05:42 PM   #12
I'm turning it in a HAAS SL30 lathe, unfortunatly it doesnt have live tooling. I'm going to do the secondary work on the VF4, (HAAS VMC)
Old 02-14-2007, 09:38 PM   #13
vr6
looks like you have the the stock setup in a bar feeder chuck. did you write the program in cam or did you use something like quick codes?
Old 02-15-2007, 02:57 PM   #14
yep, using a collet system and bar feeder, no CAM or quick code, I'm old school, write the program at the machine, out of my head.
Old 02-15-2007, 04:39 PM   #15
vr6
what did you use for speeds and feeds to do the fins? and what did you use for tooling to do that operation? i want to make a head for my motor also, but wasn't sure what about tooling choices. i'm really not in the mood to fight with surface finishes
