Old 03-17-2003, 01:14 AM   #1
Send a message via Yahoo to crisco001
Default complete overhaul
I bought an rc10gt off from ebay. the motor doesn't run as i knew. instead of replacing the piston and sleeve. I think I'm gonna just replace the motor. What are some good motors for the trucks? Preferably pull start. This IS my first real rc car, but i havenoticed a few problems that i am going to be fixing before i take it to the track. Any suggestions would be good and I'm sure helpful. Thanks in advance
crisco001 is offline   Reply With Quote
Old 03-17-2003, 07:53 PM   #2
Skully's Avatar
Have a look at OS engines. I have found them to be very reliable, extremely easy to tune, and very user friendly.
Skully is offline   Reply With Quote
Old 03-17-2003, 08:10 PM   #3
KevanB's Avatar
Really? I havent started breaking in my OS .12 CVR yet, hopefuly weather this spring break will allow. How many gallons will my OS last? And how many tanks should I break in?
KevanB is offline   Reply With Quote
Old 03-17-2003, 08:30 PM   #4
popsracer's Avatar
Default KevanB;
3-4 tanks taking it very easy, keep the temp ABOVE 200_F and below 260_F for break-in.
Once you have 4 or more tanks through the engine, you can start to lean it out for more power. Most O.S.'s will make good power around 240_F and still run decent at 220.
Expect around 9+ gallons of fuel, If you never overheat your engine and always run the tank dry, then use after run oil.
crisco001;
O.S. engines are very reliable power as 'Skully' stated. Usually though, they tend to priced higher than average. Look for a sale to get one at a decent price.
popsracer is offline   Reply With Quote
Old 03-17-2003, 11:05 PM   #5
ok, that is the motor that is on there right now. an O.S. .12cv, but its a non-pull start. it came with a bump start, but i don't like how it feels using that to try and start the truck. I think I'll just get a whole new engine for it. probably a another O.S. .12cv, but with the pull start. what else will i have to switch over besides the header? thanks for the replies also.
Old 03-18-2003, 08:11 PM   #6
xxxtracer32's Avatar
the flywheel, and motor mounts.
xxxtracer32 is offline   Reply With Quote
Old 03-18-2003, 08:36 PM   #7
popsracer's Avatar
Default flywheel, and motor mounts.
Depends. You can use Pull Start Motor mounts and Flywheel on a Non-P/S engine. The engine just sits higher in the chassis. Might want to double check which ones you have before buying new ones.
Won't work the other way around though. A P/S equipped engine NEEDS the taller mounts and flywheel to clear.
Old 03-20-2003, 01:27 AM   #8
all right! thanks for the replies guys. i'll post back here after i go to my hobby shopt to see what they say. I'd rather go with a pull start motor. thanks again!
Old 03-20-2003, 07:47 PM   #9
popsracer- i thought that if you used a pull start flywheel and mounts with a non pull start motor the starter box bump wheel wont reach the flywheel or if it dose it rubs on the chassis?
Complete or Partially complete 12th scale BryanLynn R/C Items: Wanted to Buy 6 12-17-2007 04:27 PM
My Mini LST OVERHAUL!!!!!!!!!!! Platinum_Racing Micro and Mini Scales 0 09-12-2006 09:27 PM
RTR T4 complete garrettsdad R/C Items: For Sale/Trade 4 12-14-2005 01:29 PM
1/4 car complete f/s vr6 R/C Items: For Sale/Trade 0 02-06-2005 10:33 AM
FT Tc3 complete w/ everything !!! Look... gator R/C Items: For Sale/Trade 4 03-22-2003 09:59 PM
